Btw, have you thought about going up higher in volts for that 1530 ? do a vid once you do man, im really curious to see how flys... and sounds.
Tp4070 vs 1530 neu in same boat, no changes
Those results are pretty crazy Travis, do you look at the data logging and compare loaded rpm?Comment
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I don't need to add any more volts to it. At this point it's fast enough. I may run it on 7s but that should easily put it in the 90's. This boat is sold anyway so I don't want to push it any further. The guy is more than happy with 80 on 6s. Matter of fact I'm making him order some 2s packs so he can run it on 4s and go 55-60 and not worry about going that fast. Here's the one video I have of it.
Guys please keep in mind that the 80.1mph pass was a better prop. The 65 vs 76 runs are with the same prop. I also think that (my theory) if the neu can push it a little faster then it will sort of multiply itself (no other way I can think to put it) because it will put the boat even more out the water. For example. Say the neu has the power to push the boat 5-6mph faster. Just in a power difference. Then that extra speed may create more lift and increase speed even more. That's my theory. I could be full of it or I could have a point. Who knows. If there's any doubt, I'll be glad to put the tp back in and run it again. I'm definitely not aiming to fudge anything. I just wanted to share some actual results. Believe me, I'm having a hard time believing this stuff myself. How bout I do a short video of each motor on my motor kv checker? I can do that this evening. I'll video it more this weekend and if it weren't so dang hot I'd swap motors at the lake. Here's something I'd like to point out......
The 1500kv neu in my other mono ran 65-68. Here's a video of it. Listen to the difference. This is a 1914 prop in this video.
