Ive looked in forums to see if anyone else has done this,nope. Why not? Just like to know what yall think about it. 45 on 2s, 55 to 60 on 3s. Stock upgrade metal prop. Im running the castle esc also. I overpower everything ! Is there a drawback?
5700 kv castle in Shockwave 26
I've owned a v1 and 2 v2's and they definitely don't have more room than the green one. I'd like to see a gps run of your boat. It took a lot of work getting mine past 60mph. I don't see how a 5700kv 14 series castle would push this boat to 60 on 3s. That motor has issues pushing a Exo terra buggy and the 1415 castle I have pushes the Exo just fine. So something seems a little off here....... What mods or changes did you do to the hull to handle that speed?
Here's mine so you can see it's quite stable. In stock form, you can forget it. It would not stay on the water.
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Mr.Travis I love how you just keep inspiring us SW owners. Impressive! In my testing for getting up to 45-50mph I was wondering about steer and trim tab improvements and just noticed on your video you have done that. Would you mind sharing the part #'s and installation and positions you used? It would be greatly appreciated. Also what C ratings are the batteries you recommend.SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
I don't use anything below 50c on things that take regular size batteries.
Here's the trim tabs.
http://www.offshoreelectrics.com/pro...prod=ose-80077
And here's the turn fins
http://www.offshoreelectrics.com/pro...prod=ose-80060
You will have to drill new holes. Put a dab of sealer on the old holes. They will be covered by the new hardware. This mod is well worth it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I thank you so much! I had a gut feeling that would improve it, but gut feelings don't work as well as knowledge! I bought 2 batts 35c when I started, I've used 50c in my cars, and now boat, as well as a Max Amp battery that I'm about to try in boat with 120 rated ESC.SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
Must be nice to have a lake nearby that actually has water in it
My local lake looks like a hawg sty.... literally, nice thick gooey mud & no water
AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The RoadComment
I live near Chi-town where it has rained almost every day this month! Broke record from 1902! I'll try to send it your way. I've gone from Rc boats to an ark at this point! LOLSW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
One thing to be especially careful of is heat. The loads for boating is significantly higher than what the motor may be able to sustain efficiently. I can provide a lot of background on the subject, but the point is to limit run-times significantly and track the motor temperature closely.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Personally I feel pretty confident that the 5700kv motor is way too high a kv for that boat and I'd be surprised if it didn't toast in 30-60 seconds. All the more reason I'd really like to see a video of it. Maybe with a very small prop it would work, I dunno. I still want to see this go.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
The hell with the boat(s)...
My raggedy old body can't handle the triple digit heat wave that has been plaguing the west coast since?? I've been staying inside till night time. Checked the forecast last night, there's no end in sight
It's been breaking records left & right, kinda like the rainy weather in the Chi-town (guessing you mean Chicago) area
Maybe there is something to all the talk about climate change
One thing to be especially careful of is heat. The loads for boating is significantly higher than what the motor may be able to sustain efficiently. I can provide a lot of background on the subject, but the point is to limit run-times significantly and track the motor temperature closely.AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
I know you warned me of high temps with a 3300kv motor, which I haven't been able to test yet, but with a 5700kv I can definitely see your interest in how this guy was able to pull this off , and what mods he used. 6S? - I know where there's a will there's a way for mods, but will it work is the question!! Electronics up front, batteries on the sides? Now it's been 2 months and no video or reply?? High speeds and high temps go hand in hand! I know this from RC cars too. Hey trav, what's the name of that epoxy you use for waterproofing electronics?SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
