Castle creations neu 1415 collet/collar. Proboat shockwave 26
  • jirish617
    • May 2015
    • 23
    Hey guys, I apologize if this is the wrong place I wasn't too sure where to put this. I recently purchased a proboat shockwave 26, I decided it need more speed so I bought a neu castle 1415.
    Here's my issue, the diameter of the castle motor shaft is 1/8(3.17mm), the old motor is 5mm, so where do I get a collet that'll work. Sorry if this is a stupid question, I am new to rc boating. I don't know the size of the flex shaft diameter.
  • oscarel
    • Dec 2009
    • 2128
    Did you check OSE store?
    • RaceMechaniX
      • Sep 2007
      • 2821
      The other option is buying the replacement rotor with 5mm shaft. Obviously more expensive than just buying a collet, but the 1/8" shafts are the weak link if the driveline has alignment or other issues.
      TG
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • jirish617
        • May 2015
        • 23
        Not quite sure I know what I'm looking for to be honest
          I sent you the spacer with it. What's the problem? I have the same motor in my shockwave with the same spacer. It's worked flawless. I also have the same motor and spacer in the vac u pickle. Again, flawless. Put you a drop of loctite on the sleeve, slide it in the collect making sure one of the set screws goes through the spacer and hits the motor shaft. Let it dry overnight. You'll be fine. Here's the motor in my shockwave
          • jirish617
            • May 2015
            • 23
            Holy crap! I honestly didn't even see it on there! Looked right past it!
              I told you I taped it on the shaft lol.
