I have the leopard 4074 2200kv and 180 amp esc combo from offshore electrics. I plugged it in and tested it and it is spinning the wrong direction for my prop. On my old boat I ran the same prop, and the polarity was right. Can I just switch the outermost wires on the motor/esc connection? Will this throw off the way my boat runs?
Motor spinning wrong direction?
Tags: None
Yup, just swap them around and you will be fine. I always swap the positive and negative wires. Good to go!Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!Comment
Haha, brushless. I guess I should have said "Red and black" wires on the motor/ESC. I'm weird...Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!Comment
yeah its a brushless combo. I feel like an idiot after looking it over again last night I realized it was a switch on my transmitter....Comment
Be sure to calibrate it if it is a new setup or if you reversed it on the radio.
Sent from my SM-G920V using TapatalkMy private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
Hold full throttle while you plug it in, after the beeps release to neutral.
There's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Yeah set throttle channel to reverse, turn throttle trim all the way up, then calibrate to your esc.
Once that's done, if your motor is spinning the wrong direction, simply swap any two of the motor wires.
Done
Easy
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
