I was going over the Lehner charts and noticed this "rpms are determined with 15° timing" and also the rpm ratings are based on delta (triangle) configuration. Also noted in the FAQ section is this
Which motor timing value should I use?
This depends on the load (small load - low timing / heavy load - high timing).
A "compromise" clock value would be 10º - 15º.
I'm currently running a 3080/8 in delta(triangle) at 2º which looks like it's way below what's suggested by LMT. What are those with these motors running???
