motor wind question
  • fitzloff
    • May 2014
    • 66
    motor wind question
    I have a revolt 30 with a 120 seaking with the stock motor(1800kv) that is ran on 4s and 5s batteries with a m445 prop. How do I find out the winding of the motor I am trying to set them timing on the seaking. what I have found on the net you need to know the wind of the motor to determine the timing.
    Thanks Zach
  • Mike Caruso
    • May 2012
    • 940
    If I remember its 11 degree's on the Revolt ESC. I ran back to back tests with the stock ESC and the same one you have. No gain ZIP ZERO NOTHING except it would idle around dead slow if I wanted on 4s. I pulled the 120 out and have run the Revolt ESC forever more. And I another complete Revolt setup in a Mickbees Jet boat 4s maybe be back running this week with video.
    Do It Like You Mean It .....or Don't Bother
    • fitzloff
      • May 2014
      • 66
      the only reason I went with the 120 is so I could run 5s I don't think the stock esc would handle 5s but thank you sir for your help!!!!
      • fitzloff
        • May 2014
        • 66
        I am still looking for the wind on a 1800kv aqua craft?
        • montymike
          • Jul 2012
          • 774
          Aquacraft does not state the wind rather d ory wind revolt esc set at 11° set your seaking at 12°mike
          • ray schrauwen
            • 9471
            If there are solder joints inside the rear end cover then it is a "Y" wind. If there are none then it is a "D" wind. The closest you can get with a Seaking 120 esc is 11.25* which should be fine and as close to the stock esc.
            I know the 2030kv AQ motor is a "Y" wind but, since I have not broken an 1800kv AQ motor, I don't know what is inside?
            Darin Jordan will know, you might be able to chime in on the P-Spec motor thread bouncing around right now to find out. It may even be in there somewhere already. I'm sure it has been published though.
            Nortavlag Bulc
            • ray schrauwen
              • 9471
              These are Seakings ONLY timing settings: Timing (0.00/3.75/7.50/11.25/15.00/18.75/22.50/26.25)
              Nortavlag Bulc
              • montymike
                • Jul 2012
                • 774
                Yup my mistake thanks Ray 11.25, thats what i set min e at and thanks for the way to check the d,y on the endbell.
                Will e helpfull in the future for un known winds. Will check my 1800kv at home against my 2030 in my boat.
                thinking it is a y wind since the parameters on the speed control can't be change.
                • fitzloff
                  • May 2014
                  • 66
                  You guys are awesome thanks for the help!
                  • Luck as a Constant
                    Make Total Destroy
                    • Mar 2014
                    • 1952
