Water jacket on motor, HELP!
  • Varooom
    • Nov 2013
    • 96
    I have to ask for help once again. I have a Neu 1527 motor and water jacket for it (both from ose).
    I have tryed to get the water jacket on the motor with no success.
    The instructions simply say "oil the o-rings and outside of the can and slide it on". Ya, right.
    I have tryed 2 different oils, and a thin grease, it will not go on.
    Looks like the end bell is very slightly larger than the can.
    Can I take the end bell off, output side of can, or am I just doing something wrong? 4 allens hold the end bell on. Can I take them off without screwing up the motor?
    Is there a better way?
    Thanks for your time and help.
    varooom
  • TOFTS
    • Aug 2013
    • 15
    Like most tolerance fits may work on this. Throw the motor in your freezer for 20 minutes and warm the cooler with a hair drier
    • Varooom
      • Nov 2013
      • 96
      Thanks TOFTS,
      Still did not work.
      I did a search and did not find anything, obvously knowone else is having problems with this.
      I must be doing something wrong
      thank you,
      Varooom
      • photohoward1
        • 1610
        Sometimes one end of the can is rounded. Also put it flat on a table and push or I have even given it a light tap with a mallet. (PUT A PIECE OF WOOD OVER THE COOLER END FIRST BEFORE YOU TAP IT.) BE GENTLE. Post some picks if you can.
        • Varooom
          • Nov 2013
          • 96
          Ok, after much searching I found where it is better to use dish soap instead of oil, tryed it, no help.
          Then I tead another that suggested removing the endbell (output, shaft side).
          Still will not go on. Now I cant get the endbell back on, seems Neu has a trick for that too.
          I guess I am just too stupid for this.
          Should have stayed with rtrs, looks like I will have to send the motor to Neu to put the endbell back on.
          Then I will get rid of this whole thing and stay with my Revolt,
          thanks for your time,
          Varooom
          • Varooom
            • Nov 2013
            • 96
            Sorry guys, l am a dumb a$$.
            I have a 1527 motor and ordered a HRC jacket for a 1515motor because I wanted a shorter jacket to fit thr rear motor mount.
            The 1515 jacket is slightly smaller in diameter than the 1521/1527 jacket. You wont find deminsions anywhere but that is why I am having trouble. I found a post from Dave at HRC that explained it.
            So the fix is, I will order a 1521 jacket and modify a different rear motor mount to fit and get a little better cooling.
            Thanks for your time, sorry for my rant,
            Varooom
