Hello gang,
Hope y-all had a great Christmas!
I have some nubie questions about the Neu motor I bought for my TFL Ariane 2 (36.6 inch mono).
I got a Neu 1527 1.5D, 1500Kv, 8mm shaft motor from OSE to power my Q mono sport FE. I will be running 6s.
First question, the box and motor are labeled 1527 1.5D but is not labeled 1500Kv anywhere. I guess I just take there word for it that this is a 1500Kv motor? The box does have what I assume is a part number 2011-009524, maby this designates 1500Kv?
Next question, the shaft is 8mm smooth, no flat spot and about 1 inch long. Do I dare grind a flat spot or will this destroy the balance? Also I assume the shaft is hardened and very hard, what would you grind it with?
It may also be a bit too long, I have not mocked it up yet but if too long can I cut it? With what? I have not ordered a collet yet, is there one that goes on a smooth shaft (no flat spot)?
Third question. The motor has 3 black leads for the ESC. The only boat I have experience with is my Revolt. Motor leads are red, yellow, and blue which match up to the ESC leads. I assume (again) that it does not matter, connect them up and change them if the motor turns the wrong way? (Have not purchased ESC yet, that question will come in another post).
Last one, my motor mount has a clamp that goes around about the middle of the motor besides bolting to the front of the motor. I again assume I need to get a water jacket that fits from the front of the motor to the clamp, only covering a little more than half the motor. The motor is 4 inches long, the water jacket will only be about 2.5 inches. This cant be good for cooling, am I missing something?
Ops, forgot one more question. The motor shaft spins easy in my fingers. The stock 1800Kv in my Revolt is very difficult to spin the bare shaft. Is it normal for these motors to spin so easy?
Sorry for all the questions, I don't know who else to ask, and I do not want to fry anything
Thanks again for your time and help,
Varooom
Varooom
