Hey those outrunners like high timing.
In my P1 KOS mono with modded setup but still running the stock V500 2000kv motor,
With the stock 60a esc that is a turnigy 60a esc and running on 3s,4s,5s, for testing with a x440/3 prop.
I started at 15.00 and ended up at 26.25 and with that it ran the best for speeds and temps to.
Lenny i was thinking to start 11.25 but it confuses me the 600 size motor with 1760kv.
This is like fightercats 3740 t600 and 5-15 degrees recommended.
Also eny info is welcome!
That a good idea to test at 11.25 than,
Than work your way up from there.
Just do not be surprised by high temps from those motors because they can take more heat than inrunners,
My motor was running between 140F and up to 210f some times.
But with the higher timing it did run cooler and I gained a little speed to.
