10s rigger build using castle 2028 and castle hydra ice 200 hv
  • pond skipper
    • Sep 2010
    • 175
    It has been quite some time from my last post on here and thought I would share with everyone what I was up to. I have recently acquired a gas JAE rigger kit "New version" and lets face it, I hate gas engines for rc... I already had a castle 2028 that I was going to run as an inexpensive option for a large mono that belongs to my father (old heavy 43" sightler mono) and we both got the bright idea at about the same time to try it in the rigger running on 10s 1p 5ah thunderpower 65c lipos (two 5s 5000mah packs in series) turning a 2.5 X 1.4 two or three blade abc prop and I was wondering if anyone may have any experience in trying that motor in a rigger yet? I know thats a fairly stout prop for that motor on 10s and I may end up having to cut it down a bit but im not sure yet because I know with a rigger the constant draw will be reduced due to hull design, obviously, but how much will remain a mystery till I get some runs in with it and check the data logger. Im definitely going to start with the 2 blade to keep the "bite" down just to be on the safe side and see how it acts, who knows, it may do just fine and may even end up with a 2.5"X1.6" 3 blade in the end... Any thoughts or comments???
  • urbs00007
    • Jun 2011
    • 826
    running a twin 90 rigger with 2230 12-s bestspeed todate 96mph. rtr 20 lbs.
    • urbs00007
      • Jun 2011
      • 826
      pics on my post 7-12-2012 post #17
      • pond skipper
        • Sep 2010
        • 175
        Good God man! Two 2230s? That's insane! What mah packs are you running?
        • pond skipper
          • Sep 2010
          • 175
          That's a horsepower to weight ratio of about 1.3:1.0, that's awesome!
          • urbs00007
            • Jun 2011
            • 826
            rigger
            twin 90 size one 2230 2 6-s packs
            • pond skipper
              • Sep 2010
              • 175
              Oh ok that sounds more like it... Sorry about the confusion, what's your run time and what prop are you running if you don't mind me asking?
              • urbs00007
                • Jun 2011
                • 826
                10 -s rigger
                about 2 1/2 minutes using the 80% rule. never hit the lvc yet. have 2 sets of batts this year. 96 mph with grimm 65 x 100 . 3 inch diameter abc (cant read numbers on hub ) high 80's . mark fiera suggested some electric props from prop shop to try. hope to break 100 soon. in full oval trim .
                • pond skipper
                  • Sep 2010
                  • 175
                  That would be absolutely ridiculous! I'm starting to get excited now, wonder what the speed will be for the thing I'm building...
                    • 9488
                    sounds like you will!
                    any running videos of this beast?
                    • pond skipper
                      • Sep 2010
                      • 175
                      That grim 65x100, I'm guessing the 100 represents the total pitch correct?
                        The OP's 2028 will run near 80 with the 2514 prop. To go faster he'll need more pitch, I'd not use a three-bladed prop this size. I doubt that he'll be able to make 6 laps plus the mill lap without the pack getting too low for good longevity.
                        • pond skipper
                          • Sep 2010
                          • 175
                          80 would be awesome, I could always go to a 2516 if needed as long as the amp draw isn't too high. Just received the last piece of the puzzle via UPS, two 5S 5000mah 65c thunder power lipos. Now I just need to seal the hull and do some finish sanding and put it all back together and go run it. Does anyone know how to post photos on here from an iPhone?
                          • pond skipper
                            • Sep 2010
                            • 175
                            Does anyone have any ideas on how to form a cowl for the motor/esc/battery compartment? I thought about using acrylic and forming a bulge in it to fit over the motor using a heat gun.
                            • urbs00007
                              • Jun 2011
                              • 826
                              10-s rigger
                              i vacuum formed one with abs ( you can see it in my post ) check those battery packs with cheap esc. bought (2) 6 cell 5000 ma packs thunderpower 65c packs. first plug-in to jeti-spin 300 one pack blew up thunderpower said it had a bad tap and replaced it. jeti charged me 250 to replace brand new never used esc original cost 530.00 780 bucks !! total just a warning.
