Motor Position
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    Motor Position
    I'm building a DF33 and was wondering if there a rule of thumb in boat building on motor placement? This is the first bare hull build i have done figured i better ask before i epoxy.
    Im Only Responsible For What I Say Not For What You Understand
  • Vortech C5
    • Feb 2011
    • 94
    Hello,
    I have been following your build! Nice work! You are going to love that boat!!! I have the same one. I mounted my motor towards the back of my 33", but don't have rails. I have a 36" DF with rails and mounted the motor in the front. Both times, I made sure my CG was 30% from the transom. They both run awesome. In short, where you mount the motor will dictate where you put the batteries. Good luck!
    Ray
    • MAMBA2200
      • Jul 2012
      • 1202
      well im using a ul-1 upgraded flex and where it is puts cg about 30% but im doing it so i have maximum battery location to shift the weight around just didnt want to make a huge mistake but i want weight in the front to try to avoid the blow over
      • h2o 1
        • Sep 2011
        • 770
        Mamba ,ur gonna run a .150 flex with the Leo 4092? If so, thats massive torque for such a small cable!
        • MAMBA2200
          • Jul 2012
          • 1202
          think i should go bigger ???
          • h2o 1
            • Sep 2011
            • 770
            YES! Thats alot of power. Could lead to headaches! I'd go with the .187 flex.
            • jim82
              • Jan 2013
              • 1358
              deff. go with a .187.. thats what i use with my 4082 and 4092.
              • MAMBA2200
                • Jul 2012
                • 1202
                Ok thanks for the heads up
                Sent from my DROID RAZR using Tapatalk 2
                • MAMBA2200
                  • Jul 2012
                  • 1202
                  ok just ordered a new .187 cable and a etti motor mount so i should be good now since kintec has my motor mount on backorder the etti will be a better mount anyway
