MM18 motor
  • ken webb
    • Oct 2010
    • 69
    MM18 motor
    What is a good motor size for an MM18?
  • Chilli
    • Jan 2008
    • 3070
    For a spirited sport runner, I think a Leopard 4074 would be a nice match. You could make anywhere from a 1800 to 2000 kv version work with a Turnigy 180 speed controller depending on what prop you want to use. i would also go two 4S packs in parallel (4s2p). It will run circles around the .18 version.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • ray schrauwen
      • 9471
      Depending on your experience a UL-1 motor and 180 esc would work too. If you need more speed you could move up to a larger motor after.
      Nortavlag Bulc
        I tried the UL-1 motor in mine, but it was just a bit too much. The 1800 Kv motor worked better - just as fast with less heat and amp draw. But my MM is the full-weight version, the light weigh versions may work great with the 2030 motor.
        • ray schrauwen
          • 9471
          That is correct Fluid. My MM18 is the heavier version. BUilt very well mind you!
          Thanks for adding important info!!
          Nortavlag Bulc
          • Chilli
            • Jan 2008
            • 3070
            I was thinking of suggesting 1800kv motor also. She works real nice on the 30 inch Revolt.
            Mike Chirillo
