I know from reading and experience that a 1515 1y should be at 15 deg. timing but is this prop dependant sorta because I know as timing increases the motor spins faster but with less torque and vice versa on the lower settings.So say im running an m445 is it ok to run lower timing without worrying about heat or should it be a constant 15 no matter what prop or hull I use? just being careful lol.Plus I have been busy and had no time to test lower settings myself anyone got info ?
castle 1515 1y timing?
While the timing does depend on the load (higher load = higher timing), for a normal amperage draw using 15* on that motor won't get you into trouble. When I run that motor at over 200 amps it runs better at 20* advance, but that's too much for a normal amp draw.
