TP power brushless motor.
  • SSchevy
    • Aug 2011
    • 9
    Hi,
    whether the TP power brushless motors with high quality?
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    I don't have the one you linked to, but I have a couple of the 4082 2180kv motors in a hydro & a mono & they out perform the same size Leopards I've tried in the same boats any day. More efficient, more power & less heat with the same prop, battery & laps.
    Just my thoughts & observations.
    • znus
      Broke, as usual
      • Jun 2011
      • 120
      TP Power are great! They deserve way more recognition than they get.
      25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
        • 9488
        sounds good!
        why have I heard TP motors are a hit or miss?
        • martin
          • 2887
          Steven Vaccaro tested a TP 4092 1800kv & Leopard 4092 1730kv both on 6s in a 36" DF cat hull both on x450 prop, the TP ran 60mph & the Leopard 67mph. He said the Leopard had so much torque that he had a use i believe 10,000 mah batteries over the 5000mah he had previously used to get more weight in the boat & still ran 65mph with the Leopard.
          • jcald2000
            • May 2008
            • 774
            Sounds like one was a deta wind and one was a Y wind???
              • 9488
              I remember that thread he started...
              • martin
                • 2887
                The specs ive seen on both motors they are both D winds.
                Leopard 3D no load current 4.5a.
                TP 6D 2.5a.
                • Basstronics
                  • Jun 2008
                  • 2345
                  I just picked up a used 4084 2200 KV.
                  It wont be a fair comparison though because my Leopard if a 4074 2200 KV.
                  Initial thoughts- WAY stronger magnets. This thing cogs like a hog!
                  • martin
                    • 2887
                    incease in cogging is no indication of a more powerfull motor.
                    • Basstronics
                      • Jun 2008
                      • 2345
                      Increase in magnet strength is an indication of more torque.
                      I could have both rotors Gaussed...
                      • keithbradley
                        • 3663
                        There was obviously a variable that had not been accounted for. If he used 10,000mah for one and 5,000mah for the other, that could be the difference.
                        I have tested a number of Leopard and TP motors and I have not experienced this phenomenon. That test is not a fair representation/comparison of motors.
                        www.keithbradleyboats.com
                        • martin
                          • 2887
                          He tested them both with 5000mah & got 60mph & 67mph, he then fitted 10,000mah with the Leopard to increase weight to help with the torque problem & still got 65mph.
                          • keithbradley
                            • 3663
                            So it went slower on 2p?
                            I think he needs to re-test. I suspect that 67mph reading was innaccurate.
                            • martin
                              • 2887
                              I believe he used 2 3s 5000mah in series for the 60mph & 67mph runs.
