Initial safe motor timing for Leopard 4082 1600kv?
  • izcain
    • Mar 2012
    • 274
    Just wondering what everyone thinks is a safe timnig setup for starting on a 1600kv 4082 leopard motor. Also what is everyone else finding as optimal timing?
    • 7990
    Start with 10 degrees advance. "Optimal timing" depends on the application, not the motor. How many cells will you run, how many amps will you draw? Sport running or SAW type running?
    • izcain
      • Mar 2012
      • 274
      I kinda figured that the optimal timing would be on a hull by hull basis.
      This is in a cf daytona with a Seaking 180A esc and going to run 6s
      I am looking to do some sport running at first then graduate to quicker speeds as I get the bugs worked out (me included in those bugs lol)
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        Mine runs from a SK180 also. My timing is at 11.25 degrees. I think thats what the programming card says. Its the only 11 degree timing option anyway. Use quality batteries and start with an X445 prop. Ill post a link to some new, interesting batteries Ive yet to try, but have good reviews from a few racers here.
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          Here ya go
          Id run two 3s packs in series.
          • dana
            Banned
            • Mar 2010
            • 3570
            my leo 4082 1800kv is at 11.25 right now. it just "felt" better to me. i have no technical jargen to back anything up heh… but i did try 7.5 and, i dunno, it just didnt feel right. optimal for me is what felt good, so ill prolly blow it up but w/e lol. its a mean machine hull 5s m445
            • izcain
              • Mar 2012
              • 274
              I was thinking I was going to run some nano tech (I have had good luck with them) they are 45c rated 5k mah
              • izcain
                • Mar 2012
                • 274
                I figured I was going to start with a M445 prop and work from there. Is there a difference between the M445 and a X455 Seemed from the specs that they were one in the same?
                • dana
                  Banned
                  • Mar 2010
                  • 3570
                  yes, the m prop have the tongue removed… same prop other than that
                  • dana
                    Banned
                    • Mar 2010
                    • 3570
                    i think the x445 has a larger hub size as well
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3278
                      M series are de tounged. They unload the prop a bit more an can give a bit more top end speed. Use the X series first for the maiden. Only progress to more aggressive props after you verify temps are in check.
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        Dana, why are you blue? Cant breathe?
                        • izcain
                          • Mar 2012
                          • 274
                          I thought that a detounged prop is easier on the motor?
                          • dana
                            Banned
                            • Mar 2010
                            • 3570
                            i hold my breath when i play guitar lol
                            • LarrysDrifter
                              Big Booty Daddy
                              • May 2010
                              • 3278
                              You will have more traction with the X prop and less cavitation, the opposite with an M prop. De tounged props cavitate when accelerating from a dead stop or coming too slowly out of a turn. This has been my experience anyway.
