Castle/Neu 1406 Wind Specs?
  • jimi911
    • Jan 2010
    • 205
    Does anyone know if the 1406 Castle/Neu series is D or Y wind? They have 4 models:
    1406-4600kv Motor
    1406-5700kv Motor
    1406-6900kv Motor
    1406 7700kv Motor
    Emailed a few but got a lot of huhs?
    www.whittingtonracing.ca
  • Marcus_Germany
    • Feb 2012
    • 14
    Hi
    the pictures from castle will not help because it looks like as if all engines 1Y wind
    but the ratio is about 1.73 of 1Y to 1D
    greetings Marcus
    my bad English are special effects of my keyboard
    • RaceMechaniX
      • Sep 2007
      • 2821
      An educated guess based on Neu 1400 series chart:
      7700 kv=1.5D
      6900 kv=1Y
      5700 kv=2D
      4600 kv=1.5Y
      Looking at all the other Castle motors which have traditionally been Wye only winds I would also propose
      7700 kv=1Y
      6900 kv=1.5Y
      5700 kv=2Y
      4600 kv=2.5Y
      That's my guess. I don't think they make a 1D as it would be closer to 9000 kv. The 7700 might be a 0.5Y and then 1y, 1.5Y and 2Y respectively.
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Alexgar
        • Aug 2009
        • 3534
        i dont know if this helps but scroll down to the aveox motors as i believe they are the neu predecessors
        • jimi911
          • Jan 2010
          • 205
          Good guessing guys!
          I'm leaning towards the lower Kv option, but the hull has not arrived so I am not sure if it'll fit (JAE Mini Sprint)
          • Alexgar
            • Aug 2009
            • 3534
            I dont have a mini sprint but do have a renegade rigger a little smaller but id say anything over a 28mm would be overkill in power and size of battery required for a motor that size just my opinion
            • jimi911
              • Jan 2010
              • 205
              I have one of the 28mm leopards (2860) in a micro drifter. The wattage output is more than a 1506 series neu. The boat is stupid fast, but I have not been to impressed with the amp draw (D wind). The one thing I have heard about the 1406 motors is that they are very efficient. I was sort of hoping I could run this motor on the conservative side and (if it is a Y) get longer run time and decent performance. The other option i was looking at was a 1100 series neu (1112 or so) but again their wattage output levels are similar.
              Than there's the price. You can get a 1406 for $65 ... not the worst gamble :)
              • Alexgar
                • Aug 2009
                • 3534
                the aveox 1406 2y i had was 3000 kv and was 43 contant 80 peak a very good esc in sending you a pm for a link
                • Darin Jordan
                  • 8335
                  The Castle/Neu 1406 motors listed are all "Y"-winds... More efficient and build less heat than D-winds... A little less "punch" off the line... This is directly from an expert at Castle Creations...
                  Darin E. Jordan - Renton, WA
                  • jimi911
                    • Jan 2010
                    • 205
                    Perfect ... thanks Darin!
