2650 castle 1512
  • rc rob
    • Jan 2012
    • 10
    2650 castle 1512
    I was wondering if my castle 2650 would push a 32" cat I have a 180 tunigy esc and already have the motor out of my jammin x2 so im trying to get away with what I have. I planed on runing 4s1p thanks rc Rob. The cat is a godspeed from r2 hobbies.
  • siberianhusky
    • Dec 2009
    • 2184
    Probably go up in smoke, thats close to 40 000 rpm, 3s would be a much better choice even though your amp draw will go up.
    Should be aiming for about 30 000 rpm, or a 2000 -2200 kv motor on 4s.
    40K is around what the very experienced straight line speed guys run, they don't expect their equipment to last the summer though, they usually are running right on the edge.
    YOu would have to turn a very small prop to avoid overloading the system, and would probably not be very happy with the performance with a stock prop.
    I'd look at a different motor, something like a leopard 4074 2000kv or a bigger Castle of lower KV, Suppo t600 outrunner about 2000kv (I have one strong motor!)
    Cars and boats are totally different in motor requirements, no gearing in boats and much higher loads on the motor.
    • Boaterguy
      • 1760
      +1 on the suppo 2000kv, i have one running on 5S, unfortunately i don't have 4S packs but it's a high RPM setup, and it's still spinning a 42mm prop with no cooling. (added a fan to keep temps down and water on the ESC)
      • Snowride
        • Sep 2010
        • 297
        If you are on a budget, this will make that 32" scream. Just need to prop it right. Plus it can handle up to 6S if you decide you want to. Real good combo with that 180 esc you already have. http://www.hobbyking.com/hobbyking/s...dProduct=17698
        • rc rob
          • Jan 2012
          • 10
          Thanks guys the only reason I wanted to try that motor is I wanted to go smaller in my buggy so I was going to try the 2650 in the boat. I run it on 4s in the buggy but it makes sence that it will draw more with no gears. I have alot of 3s packs for my planes so thats not a big deal to run on 3s and I have a octura 442 do you think that is to much prop on 3s.
            • 9479
            It kinda depends on your goals, speed wise...
            with the right prop (small) you could get away with it
            • rc rob
              • Jan 2012
              • 10
              I would like to do around 50mph what speeds do you think that xk 4082 1600kv would get me. Kinda a stupid qustion unless sombody has one.
                • 9479
                I'm not a pro, but with your original motor and a 40mm prop you might see those speeds...
                • rc rob
                  • Jan 2012
                  • 10
                  Wow that surprises me only a 40mm prop I ran that 442 on my stock pro boat with good runing temps. I dont no boats very well yet only planes and cars so have pateints with me and thanks for all the info from every body its my first time on this site.
                  • Boaterguy
                    • 1760
                    depending on your plane packs, they likely won't hold up.
                    what are the ratings on your biggest (c rating and mah) 3S lipo?
                      • 9479
                      your rpms bro..
                      your spinning at almost 40k rpms with the castle motor so prop needs to be smaller, the PB is running much much less, so you can swing a bigger prop
                      different kv's need different size props
                      • rc rob
                        • Jan 2012
                        • 10
                        rpm
                        your rpms bro..
                          • 9479
                          not following you bro?
                          • rc rob
                            • Jan 2012
                            • 10
                            I dont no what im doing this is my first time on eney forum sorry.
                              • 9479
                              Oh man, we all on this site are still learning...
                              Welcome to OSE, and hang on bro!
                              You will learn a lot on this site.. :)
