My PT 45 just ate another motor!!! This is the 3rd 1527.5y in 1.5 years. They just melt down and smoke and every time I send it back they tell me its from excessive vibration on the three wires coming out of the motor. I wire tied each wire down to a wood support so they could not move anywhere but again today ....poooof!! Temperatures NEVER pass 100-110 on the motor or controller. Batteries are 65-130c 5,000mah Thunder Powers, ESC is a Hydra 240HV, boat comes in at 13lb exactly, prop is x648 cut down. I spin it to around 42,000- 43,000 ...well below what Neu tells me is safe. I make no more than 3-4 back to back SAW runs. I know there is a big amp draw but again Neu says it would be ok. Any ideas. This is costing to much for a top of the line motor way to often.
Neu motor issues
Since your saying the wires are held down at the rear the obvious question is what motor mount are you using? Is it supported front and back? I know alot of folks only use a front angle bracket and leave the back up in the air. Got a pic?
The other source of vibration, even with a mount that has both the front and rear support, that may be the culprit is how stiff is the floor? I see folks glueing down one of those floor mount designs and leave the floor still thin. That can allow the motor to see movement.
JohnChange is the one ConstantComment
Motor is bolted front and rear. Entire assembly is mounted on seperate flooring and everything is fiberglassed down. Nothing is moving anywhere. I really dont see a vibration causing this. This hull is big time reinforced to hold everything in place in the event of a blow over and thats why it comes in at 13lbs.PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mphComment
Gary,
Is the wood block helping or perhaps hurting? The 240HV has twin sets of 10AWG wire running to the motor which are heavy. Perhaps the vibration/jouncing of the boat is causing the wires to excessively stress the motor leads.
I have double shrinked the wire in some cases and in others I have seen people using plastic bushings between the motor endbell and leads when space allows. However the 0.5Y has pretty large leads which makes additional insulation difficult.
A pic of the set-up would help diagnosis. And unfortunately, if you send that motor back in for service chances are you will get a silicone lead version.
BTW, John I recieved the 1520 today. Thanks,
TylerTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
You are pulling some major amps.............."Temperatures NEVER pass 100-110 on the motor or controller"................but what are the wire temps..........are you literally melting them............????NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
My PT 45 just ate another motor!!! This is the 3rd 1527.5y in 1.5 years. They just melt down and smoke and every time I send it back they tell me its from excessive vibration on the three wires coming out of the motor. I wire tied each wire down to a wood support so they could not move anywhere but again today ....poooof!! Temperatures NEVER pass 100-110 on the motor or controller. Batteries are 65-130c 5,000mah Thunder Powers, ESC is a Hydra 240HV, boat comes in at 13lb exactly, prop is x648 cut down. I spin it to around 42,000- 43,000 ...well below what Neu tells me is safe. I make no more than 3-4 back to back SAW runs. I know there is a big amp draw but again Neu says it would be ok. Any ideas. This is costing to much for a top of the line motor way to often.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
Does it burn up on saw passes only. I believe you stated your voltage was 18.5 volts. How did it do using 14.8 volts?
I will quote you from an earlier post
"Mine loaded comes in around 12.5 lbs unfortunatly but has a consistent top speed of 87-89mph on 18.5 volts and a best top speed as of today of 73 mph on 14.8 batteries. Very stable hull when its dialed in and took me a year to get there but well worth it".Comment
Wires are triple insulated coming out of motor , not all the way in though,and come in hotter than the motor and controller but never anything melting. Fluid at one point estimated amp draw over 300 going by some of his boats. Steve, cells are Thunder Power . I run two 65-130c 5,000 packs in parallel with consistant top speeds of 93-94 at this time.Voltage drops are around 1.5 -- 2.0 volts at top speed. Rumdog about 40 passes but this time less on this motor.Detox I only ran 14.8 volts just to see what it would do so I really only run 18.5 all the time. Again, talking with Steve Neu he did not say that I would have a problem and even ended up with the 2,500kv from stepping up from the 2,300kv so this problem goes way back. At this point I would say the motor can not handle it. Its funny though because I could not keep a controller in any SAw boat and now my HV 240 is over 2 years old with countless passes , crashes and drownings on it and she still ticks like a timex LOL.Last edited by Gary; 11-27-2011, 01:18 PM.PT-45, 109mph, finally gave up after last bad crash
I also have had two 1515 1Y's go bad (one burned to a crisp) ; both in reasonably mild 4S setups. I recently aquired another one with the silicone wire update. BUT one of the the darn silicone wires had a split in the silicone insulation (exposing the bare wire inside) right where it entered the endbell. I applied some liquid epoxy insulation on the bare wire, and then siliconed the heck out of the wire/endbell junction in several applications. Looks crappy, but It's survived one racing season so far.
The second one that I got back from Neu after a rebuild has the silicone wire as well (with some clear shrink over the wire as it pases through the endbell) and when I put it in use I'll do the silicone thing to it just for safety's sake.
It would be nice if at some point the Neu motors would have a strain relief like the Castle/Neu motors - maybe designed to be more cooling jacket friendly.
DSC02778.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
