I have turnigy motor, But do not no it kv,Is there a way to find it out ?
  • lenny
    • Sep 2010
    • 4294
    Hi,
    How can i find the kv of a motor if unknown ?
    Its orange colored and has 4 vents at each end, I think it a Turnigy motor 36MM/56mm/ / 5MM shaft. 2 pole.
    It looks like one.
    Thanks for any info.
    ? ONLY IF THEY WORK
  • kookie_guy
    • Jun 2008
    • 897
    is it one of these.....
    http://www.hobbyking.com/hobbyking/s...idproduct=6527
    • Darin Jordan
      • 8335
      If you have an Eagle Tree, you can hook it up, measure the max RPM and voltage, and do some division...
      Darin E. Jordan - Renton, WA
      • lenny
        • Sep 2010
        • 4294
        I think so, It looks just like them, But no tag is on it, I got it off of swap shop on hear, But no info on it.
        Trying to use it for a 2s setup for my Rio ep to go brushless soon with low amps for esc.
        It feels like two pole to me when i spin it.
        ? ONLY IF THEY WORK
        • Boaterguy
          • 1760
          there is a way to do it with a poer drill, or another motor with a set RPM, I forget how, it might be on the tips/tricks section of this site.
          • lenny
            • Sep 2010
            • 4294
            I saw in tips something about a using a drill with known rpm,
            But unshore about how that works.
            No i don't have a eagle tree yet.
            ? ONLY IF THEY WORK
            • Boaterguy
              • 1760
              you put the motor shaft in the drill and spin it at an rpm, use X. put a voltemeter on two of the wires, use the voltage you get as Y. then run them through this formula. (X/Y)/1.41
              the answer you get will give you your motor KV
              • lenny
                • Sep 2010
                • 4294
                Just tried it, But volts are not stable on the meter.
                600 rpm drill, DM-55 Greenlee multimeter.
                ? ONLY IF THEY WORK
