Castle 1800kv in geico
  • dano1
    • Dec 2010
    • 403
    Installed a castle 1800kv motor and turnigy 125 amp esc, im running a x642 and id like to know where this set up would be best to run on timming wise and battery maxx, i took it for a test run on 4s then 5s then 6s and got some high temps on esc, couldnt open her up due to choppy water, im getting 125 degrees at the esc and water is feezing cold, motor and battery are cold, dont wanna burn anything up. any advice would be appricated
  • Make-a-Wake
    FE Rules!
    • 5557
    You runnin' the 1512 or 1518?
    • Rumdog
      • 6453
      5s max. 15 degrees timing. 125 isnt too bad on the esc. Was this on the caps or?..
      • dano1
        • Dec 2010
        • 403
        Ice cold water and was on esc itself, caps were tad cooler and motor is 1500 series
        • dano1
          • Dec 2010
          • 403
          1512 motor
          • Rumdog
            • 6453
            • Rumdog
              • 6453
              temp was probably from spikes while running 6s. 5s should be your max if you want good temps.
              • dano1
                • Dec 2010
                • 403
                i tried 4s and 5s....still was getting warm in ice cold water....and didnt get to make a good pass....didnt push it, and i know thats not great on esc just half throttling
                • dano1
                  • Dec 2010
                  • 403
                  whole idea behind this is to get some power out of it, im not totally sure where the timming is on the esc, im going to check it, the esc when i got it was a paralel set up....dunno if that means anything and im in series now
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1598
                    Ran the same motor in mine on 6s with no trouble. You might be a little aggressive on your prop selection. I was running a m440.
                    FE BOATING: Less like a hobby and more like an addiction!
                      • 9488
                      that's a good point
                      almost 40,000rpms
                      • 6sHyper
                        <<<Surfs up!
                        • Jan 2011
                        • 597
                        I'd recommend 7.5 timing on that motor, i had best speed readings on mine at that, my temps were real cool though, If your wanting to run 6s i would highly recommend throwing a T180 in her, your temps would be way lower too.
                        • steveo
                          • 1454
                          try a x 442 might not be letting the motor wind out, just as an example on different boat i was using a x645 motor was very warm switched to a x447 gained 5 mph and temps were cooler
                          • dano1
                            • Dec 2010
                            • 403
                            i like the seaking 180, been good so far, im gonna make sure that esc is set correct then run again and hopefully get some serious passes in and check the temps
                            • 6sHyper
                              <<<Surfs up!
                              • Jan 2011
                              • 597
                              I thought it was a 125 amp???
