am i right in thinking the timming on the leopard 4082 1450kv 4d should be between 0/10 or low timming setting?
timing for leopard 4082 1450kv 4d motor?
Reference Neu Motors:
Use low (0-10 degrees)or medium(10-15 degrees) advance settings for “Y” wind motors and low (0-10 degrees) advance settings for “D” wind versions. -
Timing ?
Hope you can help with similar question on Leopard made for Tacon 4 pole motor.Here is the # of the 2 motors I am using for a cat. LBP 2860 B/4D 2550 kv.I am running both on 3s and need to know if I should use the low timing like all the rest of the D motors.The timing on my 120a ESCs can be at 0,3.75,7.5,11.25,etc.The data sheet has the exact same specs as LBP 2860 4D 2550kv.Comment
7.5 is a good starting point, maybe try dropping down one and see how it works out for ya.Comment
