can someone answer this for me would the leopard 4082 1500kv get higher top speed than the 1450kv 4082 and what speeds would they make using turnigy 180amp esc using x445 prop on 2x3's 5000mah 40/50c in series 6's
leopard 4082
On a 6s voltage set up,the 1500kv will be 33,300rpm.
The 1450kv will be 32,190rpm.Thats only 1,110rpm difference.It might not even be noticable.I run the 1500kv version and love it.It has great top speed and low temps. -
The 1500 Kv motor is a 2Y while the 1450 Kv motor is a 4D. The 2Y wind will be slightly more efficient based on the Io and RM values, but the differences are small. As Larry said, you probably would not notice a difference in performance, but I'd get the 1500 Kv motor.
JohnChange is the one ConstantComment
Neither of those motors are decent choices for that 37" hull. Maybe a 5682 2Y as its a larger diameter can and has more power then a 4082. The CC/Neu 1717 would work, and better then either the 4074/4082, plus its also only $70! To get your hull rock'n you should look at a 1521 or a 2250. If budget is tight get the 1717.
JohnNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
JohnComment
Here you go! Good motors too! I bet the sale is going to be ending in the not too distant future. Might want to get 2. http://www.castlecreations.com/promo...clearance.html
For those who are interessted i did some data logging with the 4082 in a DF33 on 6s & its pretty much on par with a NEU 1521 , in size & power . i dont think it wouuld be big enough for a 37" hull, JMO , well not if your after a good top speed ...
Running a X 648 prop
Peak AMPS - 193
Peak WATTS - 3691 / 4.94 Horse power
GPS - 62 mphAttached FilesLast edited by scoota; 02-06-2011, 11:00 PM.UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2PComment
