MHZ FOUNTAIN and CASTLE 1717 1580kV
  • Alfa Spirit
    • 2131
    #31
    Here is the MHZ Fountain
    • Make-a-Wake
      FE Rules!
      • 5557
      #32
      Wonder if an x442 will be a good prop choice for my 40" Vee with the 1717 on 6s..........???
      At least a starting point....................
        • 9488
        #33
        I think bigger?
        I have the stock S225 on my Outlaw that I will keep on it when I try my 1717 on 5s and 6s
        • Make-a-Wake
          FE Rules!
          • 5557
          #34
          Maybe so................i was wanting to start on the small side..........check temps etc.............and work up. It may well end up being a 445, 447 or s225............thanks.
            • 9488
            #35
            I hope to be able to go upto a S230 and possibly a S235
            • Alfa Spirit
              • 2131
              #36
              DISAR build a MHZ Racemaster, his hull is 1 meter long like the Fountain. A Castle 1717 on 6S will give too much RPM, I think 5S will be ok, around 30000RPM, 5S 2P (parallel) should be a nice setup
              • Alfa Spirit
                • 2131
                #37
                What do you think about this hardware, lenght is 9cm ( 3,6"), is it enough for a 39" hull?
                This hardware is expensive, If you have links to cheaper hardware that' s great
                • DISAR
                  • Aug 2007
                  • 1072
                  #38
                  The prop distance behind the hull is one big question. normally is 10%, but when I asked MHZ for the racemaster they said 55mm which is quite small I believe. I have it at 85mm and I use the eco trimax but I think that the speedmaster stinger is far better. I recommend the speedmaster stinger, very good quality, 83mm length and cheaper. 3/16 flex, teflon and 9/32" tube. the teflon just fits in the stinger very nicely.
                  If you want longer distance you can install a distance piece on the transom or elongate the stinger, but need to find out how ...
                  http://www.rcfastboats.com/
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    #39
                    I guess the 442 was too small, took my first run with my 40" fountain with the 1717 on 6s. Ran very well.............not a huge speed difference from the Feigao 580L but definately faster.............the thing is though, the 580L would come in at 125*, and the ESC fairly warm too. This motor came in after a 3 minute run at 78*..........yep...........78*. ESC was 83* and caps 89*, its a Seaking 180. This big boy wasnt even loaded up and i imagine that loading it would wake it up. I think the s230 mentioned by Brushless55 would be a good fit...........that or an Octura x447. I'll play with it.................
                    • Rumdog
                      • 6453
                      #40
                      That motor will spin a MUCH bigger prop!
                      Good luck with the Seaking on 6s though.
                        • 9488
                        #41
                        Bam!
                        this is very awesome, another great run on the 1717!
                        let us know how the S230 or the X447 run. I will buy a prop for my OSE Brothers Outlaw after you run yours
                        do you have a cooling jacket on your 1717?
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          #42
                          Bam!
                            • 9488
                            #43
                            what motor mount do you have?
                            I am having Peter make a mount for me, but I'm not sure that jacket will fit?
                            and what do you guess your speed to be on the run?
                            • Rumdog
                              • 6453
                              #44
                              Steve has jackets in stock now!
                              • chummer
                                • 636
                                #45
                                Outta stock by morning I bet!
                                "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
