Thanks Danny. I have been wanting to see a comparison. I have a Leopard 730kv on the way. I am going to run it on 10s in a 40" Insane Cat. You must have some pull to get a water jacket for that baby.......wish I had those connections!!!
Thats some serious horsepower sitting right there. I wish I had them both at my disposal too!!!
So T would you run the 730 kv @ 10 s? why not go with the 1000 plus kv and run 6s? Not disputing you just curious about your choice in the hydro. Im considering the change from the screamer to the leopard in my 1/8th. I was just wondering about what setup would be best.
I prefer to use high voltage setups. Easier on equipment and longer runtimes . Don't get me wrong tho sometimes on my smaller hydros and riggers I run high kv motors with low voltage but reliability is not there. On the setup you suggested with the 1000kv motor on 6s that just wouldn't work. The 1390kv motor would be better on 6s. 1000kv is better suited for 7s-8s depending on hull type. My Leopard is going in a Gen1 Insane Cat, it'll draw way more amps than a hydro that's for sure.
Jeff Wohlt made me a sweet @$$ coupler for the Leopard I just got in. Perfect fit might I add. I have never been a big fan of set screw couplers but a little flat spot on the flexshaft will do just fine. I will be putting in on a .250 drive line so there is nothing available at the present but I did call Octura and put in a good word as per Steven. It may help to speed up the process. In the meantime this one is doing a good job.
Have you already spinned the motor with the speed controller?
I say this beacause i have one, and the schulze 32 200 didn´t drive it correctly past 3/4 trohttle...It starts stuttering at this throttle range.....
I received now a new YGE 160 NAVY HV, and it drives it, but only at 0º timming
Have you already tried that,an input from you would be very valuable!
