The 2200KV will spin faster, KV is the RPM a motor spins at per volt so at 14V 2200KV spins at 30,800rpm and the 2030KV only spins at 28,420rpm, if you run the same size prop on the 2 motors the 2200KV motor will pull more current than the 2030KV motor in order to spin the extra 2380rpm.
yes you can, but I wouldn't advise someone new to brushless boats to run either motor on 18v unless you have a friend that is experienced with high RPM setups that can advise you on props for your particular boat, that's 36,540-39,600rpm and at these high RPMs you will need a small prop and even a tiny difference in prop load can put the amp draw through the roof and burn stuff up before you know it.
Stick to 4s for a while. 5s on those kv motors should be run in SAW style runs, not just sport boating around. Stick to 4s for that and you'll be good
To add, it's not just all about KV. Size of the motor and type of motor will play a huge part. Can you please list what motor's you are looking at & what hull they will be or already in? You don't need a some crazy amount of RPM to be fast.
1515 1y, that's a lot of motor in 22" hull. I would personnally stick to the ul power, but maybe someone else that maybe has tried it or knows more about it can help. It maybe to much though.
