Ammo and Turnigy!!!
  • xxxrems38xxx
    • Mar 2010
    • 172
    Ammo and Turnigy!!!
    hi boaters!!
    Notice to everyone, the marine Turnigy 180A esc is not compatible with the motor 2300kv ammo there is a cogging effect and a sizzling engine at low rate! If someone has had the same config with the same problems it'll be nice to give me advice! thanks to all
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    What boat is it in?
    Is it Formula fastech? If yes, did you try your ESC with the stock motor?
    Robert
    Canada
    • xxxrems38xxx
      • Mar 2010
      • 172
      yes with the stock motor all is alright nice accelerations timing at 11.25° and the esc and motor is barely warm
      • LiPo Power
        • May 2009
        • 3186
        Stock motor is one of the best motors out there for your boat. It has power and you can even up-prop your boat a little. Make sure to check temps as you do.
        Are you running stock prop or X642? This upgrade prop is all you need to get more speed and fresh set of LiPos....
        Robert
        Canada
        • ED66677
          • 1300
          anybody has ever tried this combo?
          Emmanuel
          • j.m.
            • Jul 2008
            • 838
            The ammo is a 6 pole, is the pro boat a 4 pole?
            I know somebody posted a timing guide according to the number of poles a motor has...
            Jon
            • xxxrems38xxx
              • Mar 2010
              • 172
              Turnigy marine 180A is it compatible with 6 poles motors?
              • j.m.
                • Jul 2008
                • 838
                http://forums.offshoreelectrics.com/...ght=ESC+timing
                • 6S HYDRO
                  • 1320
                  the ammo 2300 is not a 6pole motor it is a 2 pole. the ul-1 motor is the 6pole one.
                  • 6S HYDRO
                    • 1320
                    ul-1 esc runs this motor flawlessly and in the post above it states that it runs 10d timing. try the turnigy on 10 degrees
                    • xxxrems38xxx
                      • Mar 2010
                      • 172
                      the timing of my turnigy is 11.25 ° and then moved to 15 ° and I have already try all the settings and nothing to do! which is strange because with my original motor and another motor in hobbyking everything works without worries! Do you think it would come from the radio or receiver?
                      • 6S HYDRO
                        • 1320
                        maybe you got a bad motor, or the turnigy just doesnt like 2 pole motors
                        • 6S HYDRO
                          • 1320
                          have you tryed the motor on the stock esc? they run great on sv-27 or ul-1 esc's
                          • xxxrems38xxx
                            • Mar 2010
                            • 172
                            I'm going to buy a 60A aquacraft be sure that it works? is there a programming card for this esc? and up to how many lipo cells can support?
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1679
                              If the speed control operates other motors then you should be looking at the motor for problems. Could be a bad solder joint or just a lemon from the factory.
