Leopard Hobby 4-Pole CC/Neu Clones
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s -
I put an Eagle Tree system on the boat when Mark ran it. I believe the motor temp was around 110. If you search the site under a thread posted by MarkF I believe you can even find a video I posted of the Eagle Tree data playpack on my laptop from the run with the Leopard 4075.
There seems to be lots of interest and threads on the new Genesis. Here is some additional information that you may find of interest:
1. The stock Genesis set up by HobbyKing uses a 3674 2-pole brushless motor with Seaking 90A ESC turning a P1.4x 38mm Dia nylon prop. Stock speed is 60 kph or 37 MPH
2. The upgraded set up consists of a Leopard LB4074 4-pole brushless motor and Seaking 120A ESC turning a metal prop P1.4 x 40 mm dia. Stock speed with this set up is 75 kph or 47 MPH
3. The ultimate set up consists of two Leopard LB4074 4-pole brushless motors and Seaking 120A or upgrade to Seaking 180A ESC’s. Prop size is experimental. Estimated speed in excess of 60 MPH.
The motor is very efficient however it is easy to use a motor mount with integral water cooling and a factory installed silicon water jacket.Comment
thanks.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I think it went up to 113F. You can see the vide3o of the Eagle Tree Data at:
I asked Bill at Eagle Tree about the speed at 75 MPS and not a glitch - He did/could not explain it. Look at the high AMp draw and Watts....almost 3 HP!Comment
I asked Bill at Eagle Tree about the speed at 75 MPS and not a glitch - He did/could not explain it. Look at the high AMp draw and Watts....almost 3 HP!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I see a peak of 1782.2 watts, V x A= W
134 amps x 13.3 = 1782.2 divide by 746 = 2.38 HPNortavlag Bulc
It appears that HK has a ARTR hull with the Leopard 2200kv motor installed. Not a bad looker either for the bux. http://www.hobbycity.com/hobbycity/s...)_Plug-n-Drive
John.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
The motor has a lot of cog and is hard to turn. That doesn't means anything when comparring motors though. There's also a reason why this motor cost less than half of a Neu. Only time will tell how well these motors hold up over time. I think this motor is fine for sport boaters looking for a cheap alternative and not wanting the best.
MarkComment
Thank you, nice info.
I have bought really cheasy 4 pole chinese motors before that had cogg, not much and were woefully inefficient. It was a $20 motor... I use it to test esc's now.Nortavlag Bulc
That looks like a fun project!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
