The only difference is probably the custom options available but also when u handbuil you can bet that his specs are dead on. With the manufactured stuff its probably +/- 5 %. I run turnigy too love it but ist it better than a benz controller???180 amps is alot so to claim it u better be able to do it. But most manufactures rate thier stuff @ 90 percent of what it will do.For good reason ;we wanna take everything to its limits.One need to also consider this . If you wanna pull 60 amps continuous u better buy a 120 amp continuous esc over estimate always. In this hobby overkill is better.I tell you one thing Id buy turnigy before castle i bet you that cause those guys lied in my opinion on the screamer thread. Any esc maker in the world knows that firmware updates alone will not aways fix a problem .They knew that when they said it.
Leopard Hobby 4-Pole CC/Neu Clones
One other factor is that the interior of the cat is most important for my specific application since it is loaded with electronic equipment including a small Pentium computer with solid state drive and three independent wireless video systems. Keeping the motor outside means only batteries and the ESC's inside whose location is very flexible.
This a works in progress and it might be best after all to put the motors on the inside of the outer sponsons with a short, direct drive and again do steering by individual motor speed and direction. You certainly are right on the drag and I do not expect this to be any type of SAW record holder!Comment
Here is a Leopard 220O KV with water cooling in the motor mount only and fan cooling on the case. I run a complete Eagle Tree system on it with GPS. The boat is not tuned and in I run almost exclusively carbon props. However Josh gave be a three bladed polished prop and here is the Eagle Tree of the first run. 50 MPH is a non-set up condition is a good first start for this mono with my limited knowledge.Last edited by questtek; 05-26-2010, 05:30 PM.Comment
Here is a Leopard 220O KV with water cooling in the motor mount onlyand fan cooling on the case. I run a complete Eagle Tree system on it with GPS. The boat is not tuned and in I run almost exclusively carbon props. However Josh gave be a three bladed polished prop and here is the Eagle Tree of the first run. 50 MPH is a non-set up condition is a good first start for this mono with my limited knowledge.
What boat is that ? the pursuit from Hobbyking?Comment
I'm really interested in the 36-74 1290kv or 1790kv. http://www.leopardhobby.com/product/...ionID=01020211
Just can't find a anywhere to place an order for these motors.Comment
Almost....The China factory I deal with makes the Pursuit and Genesis. However the specific ones they sell to Hobby King are different. They actually have 3 or 4 slightly different models on each of the boats. The boat in the picture is one I bought in China in person and hand carried back as a bare hull with drive hardware only.Comment
I gave one of these 2200KV Leopard motors to MarkF for testing on the new Insane Hydro. We ran it with NO type of cooling at all, but only for short, fast runs. MarkF said he had a water jacket for it so hopefully he will read this and add his comment as to the specific type of water jacket he was thinking of putting on it. I think he said he got the jacket from OSE.Comment
are those equal to a 1515 in their size?
I'm getting really jazed by the possibilities of these motors.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Neu 1515 1Y
Max V 27 vdc
No load amps 2.5
Resistance 0.006
Max RPM 60,000
Shaft dia 5 mm
Weight 340 grams
Length 68.6 mm
RPM/Volt 2200, 4-pole
The Leopard brushless motors I am currently evaluating
Current rating 120 A continuous. (I have measured 160 amps via my Eagle Tree on speed runs)
Max V 22.2 vdc
Resistance 0.0062
Max RPM 50,000 with standard NGK Japanese bearings
Shaft dia 5 mm.
Weight 374 grams
Length 73.8 mm
RPM/volt 2200, 4-pole
dia 40 mm L=75mmComment
Brushless Motors Neu and Leopard:
Neu 1515 1Y
Max V 27 vdc
No load amps 2.5
Resistance 0.006
Max RPM 60,000
Shaft dia 5 mm
Weight 340 grams
Length 68.6 mm
Max V 22.2 vdc
Resistance 0.0062
Shaft dia 5 mm.
Weight 374 grams
Length 73.8 mm
dia 40 mm L=75mm
looks like I need to order 2 of these bad boys for my Twin powered Hydro.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I have a little of every thing and a made in the USA 240 that is smoked after 3 passes and only got to 90 in tempwe will see if they will warranty it lol. I would just like to say this if it was not for or knockoffs a lot of poeple would not be able to do FE becouse of the price of the parts just my 2 cents. and I hope they will give me a new 240 ESC or next time I will buy chines.
