Anyone ever seen this Neu motor run ?
  • Xcesive8
    • Jul 2009
    • 395
    Hmm nice, im glad im not the only one at present doing one of these.
    Hopefully im not working, cos yeah wouldnt mind catchn up with ya to have a chat about it.
    Let you know how i go
    Thanx mate
    • Brod
      • May 2009
      • 196
      Originally posted by sailr
      Around 800KV would be better!
      why?
      Slow gets boring fast.
      • TRUCKPULL
        • 2969
        Originally posted by ozzie-crawl
        is it just me or what
        see advice from people "kv is to low" and such then the question "whats a ct03"
        how do people give advice on whats what when they dont even know what the boat is.
        did anyone read the direct zenoah replacment in the first post
        Yes I read the direct zenoah replacment
        Zenoah motor is about 18,000 RPM
        The big advantage to FE is the RPM that we can run and the performance (FASTER) Hence the comment on LOW KV
        Maybe I should have asked, Why change it to FE just to keep the same performance??
        What is a CT03?
        I knew it was a big hull.
        At first I though it was a MONO - single motor
        Then came the SSSSS 's comments.
        Then He changed His first post to specify the two motor part, two ESC's, two sets of batteries.
        That is when I asked him to specify the type of hull, which should of had in the first post also.
        ozzie-crawl - NEXT TIME send me a PM
        Larry
        • Darin Jordan
          • 8335
          Originally posted by TRUCKPULL
          Zenoah motor is about 1800 RPM
          I'm pretty sure you meant 18,000 RPM...
          Stock Zens are around 13,000 or so, I think... Tuned versions with mods then get up into the upper teens... Not sure if they go beyond that....
          Darin E. Jordan - Renton, WA
          • Brod
            • May 2009
            • 196
            Our gassers stock motors spin about 13-14000rpm pulling a 70-72mm prop.
            Our modded motors spin about 17-20000rpm spinning a similar prop.
            i reckon that Neu motor would be a good drop in replacement for either,possibly somewhere in the middle range of performance
            • Darin Jordan
              • 8335
              I'm thinking that, all else being equal (RPMS, weight, etc), that the FE motor would have the advantage of torque throughout the power curve, where-as the Gas motor would have to "get on the pipe" to make power... The FE boat would pull HARD through the turns and out of them...
              Might be an interested matchup...
              • TRUCKPULL
                • 2969
                To get the run time that you are looking for.
                You will probably be looking at 10S2P or 12S2P per motor.($$$$$$)
                Could you not save a lot of weight and cost of batteries buy running
                TWO - 2217 1.5Y motors on 6S2P each.
                You would have half the battery weight and half the battery cost.
                There are other motors that would run on 8S2P and you would still save weight and cost.
                Larry
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  #23
                  yes i probably came across a bit rude
                  just people get frustrated and confused when people start giving advice thats not always based on the application.
                  for people to say the rpm is to low isnt necessarily correct as the motor rpm is up there with modded gas motors and torque is slightly higher.
                  but yes if people are going to do boats that are not the normal thing a full description is needed plus there goals (speed/run time)
                  • NitroVal
                    • Jun 2009
                    • 423
                    #24
                    Yea, sorry, I should have clarified the "ssssss" in "motorssssss".
                    It stands for slippery, slimey, smooth, speedy, satisfactory and, uh, supercalifragalistiexpialodocious
                    The RTR Nightmare- Electric King of Shaves
                    Now with 540s- 62mph
                    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
                    • Boatman
                      • Jan 2008
                      • 796
                      #25
                      Here is a 67" hull with 12S on each side.
                      • Xcesive8
                        • Jul 2009
                        • 395
                        #26
                        What is a CT03?
                        Larry
                        Id like to start off with where did i change my post to say im going to use 2 esc's and 2 sets of batteries???? Have a read through again, i cant find it??
                        My original post was that i wanted info on this motor ( 1900zr ) drop in zenoah replacement.
                        I at no point said i wanted to run 1,2,3,4 of these motors, i just wanted info, therefore if i had found one in a decent size gas boat, i would have considered running 1 in mono, and 2 in my cat.
                        Although No number nor hull info was needed for you users, as i was asking about the unit itself, not how it would go in my Ct03 or any of my hulls, otherwise i would have given you dimensions etc.
                        THEN
                        When i had little to NO answers about it , i thought i would continue on and reply to Stevens post, to note that i had thought of running the 2230's and the 2215's in my MHZ Ct03. I am So sorry i wrote ( 's ) after each motor, but if i ment smooth i wouldnt have used an epostrophe. I also mentioned running 12s a side in this reply which in plain english would mean i was going to run more than 1 motor !! And also at this point said this setup would be for my CT03.
                        It got confusing because after i replied to Steven in hope he would shead some light on this reply, NitroVal replied why not motorssss Which i immediatly thought he was talking about the reply above his, as thats usaly what people read last before they reply to the thread.
                        It snow balled from there >
                        Truck pull i can see where your coming from, but if you cant see from my angle then
                        Please also note that text can be read with the tone in which you choose, im not being rude here but trying to help explain.
                        The fact that you replied at all shows you were only trying to help.. and i appreciate that.
                        • Boatman
                          • Jan 2008
                          • 796
                          #27
                          Use the motor. Why not? It is a Nue and is high quality. Nearly the best you can get. If Andrew has told you this would work, take his advise. He knows this stuff very well. One heck of a price as well. Great find. If you dont use this motor the 2215 2.5Y is also a good comparison.
