interesting!
Seaking Boat ESC recalled by factory
I dont think you are supposed to use any internal bec above 3s
in my opinion internal bec's suck any way.....real FE users allways use external receiver bat packsSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
External Rx battery ( disconnect the red wire) also disables the esc onboard signal loss failsafe.
Real FE ppl ?.. dont be so bloody omnipotent. Real FE ppl make their own considerations and do whatever makes their setup the best. :)
SK180 ESC BEC is great until power is fedback via the Rx lead, Have seen only one toasted.. power was off and owner started to rotate rudder left to right to left to right.. fed power back to esc and POP.
Purely organic related failure.
Wayne.Last edited by drwayne; 08-10-2009, 06:21 PM.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of it
YOUTUBE
I killed a SK180, but I know exactly when, how and why. Rotor seized and took the ESC with it. Before that, it was flawless on 6S using the BEC and driving a very serious servo for steering.
I liked it enough to buy another one. It's going in the same outrigger with a Neu 1527/1Y and a setup that draws ~110 amps. It should be an interesting test.Brian "Snowman" Buaas
Team Castle Creations
NAMBA FE Chairman
were you using the LVC?SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
No LVC. I like to tune the race setups by capacity used and temp. Start conservative and work your way up.
I did use the programming box on the new one I set up today. Worked like a charm. Forward only, 6 cell lipo, 3.2V cut off,7.5 degrees. It has VERY smooh throttle response and a nice start up even with the big old nasty 1527 Neu.
Testing this weekend. I'll let you guys know how it goes.Brian "Snowman" Buaas
NAMBA FE Chairman
Greetings from Spanish FEboater:
I use two of this XXX180A for a while since the first ones appears at hobbycity and no any problem.
Used in a Matrix rigger powering a FEIGAO 540-9XL and drawing around 100Amps continuosly during 5 minutes on 5S, OF COURSE WITHOUT BEC, and I can tell you guys that no any problem found any time. Even in a race, the rigger crash against another boat and make a big hole in the hull, so the boat was under water several minutes till race finished, I got out the controller from the rigger, keep it almost an hour under sun shines while repairing the hull, mounted again and makes two runs more. I must tell you that before mount the ESC for the first time, i had filled out all joints and any posible hole with Silicone to prevent water inside.
Also used in a Hopf´s "El Diabolo" cat moving a BK Wanderer 540 size, 2212Kv with a graupner carbon/plastic 42mm prop, ALSO WITHOUT BEC, and still working perfectly.
No any problems found on any ways on the Turnigy180A ESC (Cross my fingers).Comment
Can you imagine....the new reworked one should be even better? Wow!Mini Cat Racing USA
I am a little confused here....you said NO LVC but you did set the new one with 3.2 cut off?No LVC. I like to tune the race setups by capacity used and temp. Start conservative and work your way up.
Testing this weekend. I'll let you guys know how it goes.SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Exactly Brian, Thats what i do...
My Ebay seller has sent me this note after I asked about the recall:
Thats nice to hear. How much does it cost to send it back to Hong Kong???Hi Ray,
Thank you for your enquires. We would like to declare that the re-call is done by Hobbywing, and we were just been notified. To express our sinceress, this item can be refunded by request in brand new condition. Thank you for your kind attention.
Should you have any questions, please feel free to contact us.
Have a nice day!
Thanks & Regards,
plus2
Maybe just Keep it.
