elbow for Turnigy / Seaking 180?
  • markwithak
    • Mar 2015
    • 38
    Any suggestions on swapping out one of the straight barbs to an elbow on the Trunigy 180 ESC?
    Would really help to avoid any possible kinking in my plumbing.
    Will one of the motor sleeve work?
    Thanks in advance for any help.
    Mark
  • TheShaughnessy
    • 1431
    http://forums.offshoreelectrics.com/...ooling-upgrade
    Thread size is 10-32. See thread for further tips.
    • Peter A
      • Sep 2012
      • 1486
      T-180 is M5. Made in china so threads are metric. Only the US makes things with imperial sizes as standard.
      • markwithak
        • Mar 2015
        • 38
        thanks for that link will look thru all that and was looking into trying to utilize the other ports so some good tips.
        I did get one fitting out so I will check it.
        • markwithak
          • Mar 2015
          • 38
          Well I did check this. On the T180A V3 it does appear that its a M5 thread its ever so slightly tighter than the brass fitting but treads in nice and no locking. The 10/32 fits too but is lose and would need some extra sealant.
          I will see what I can dig up.
          • Beaux
            • Dec 2015
            • 550
            Got a dumb guestion. I know what an esc is and what it stands for , but what does ubec stand for and the diff? thanks!
            • markwithak
              • Mar 2015
              • 38
              ESC is your speed controller
              BEC (battery eliminator circuit) from your speed controller can power up your receiver from your ESC from power from your many batts.
              UBEC (universal) or separate BEC if you run higher voltage or your ESC doesnt have a BEC or you dont want to rely on your ESCs BEC
              hope that makes sense
              http://www.offshoreelectrics.com/pro...rod=ker-HWUBEC
              this is a UBEC
              • Beaux
                • Dec 2015
                • 550
                thank you so much been around big boats all my life this little ones not so much , but i am learning iv got acouple of f1 hornets keeping me busy. having way to much fun! thanks again
                • markwithak
                  • Mar 2015
                  • 38
                  I know exactly how you feel. Same with me. I can make a big boat go as fast as you like (nothing says HP like a needle climbing on a boost gauge) and deal with good size 3p machinery at work just need to combine the two and scale it down alot, Back in the day I had some electric and nitros but cant use my servo and on/off switch for throttle method anymore.. Just search and research and alot of info on here for almost any setup you are looking for.
                  • Beaux
                    • Dec 2015
                    • 550
                    man im telling ya! iv read so much on set ups and everything else. this forum is the greatest i realy appritiat being able to join in this. iv got to save one more month then the blackjack 29 will be ordered. cant wait
