Not meaning to upset anyone but offer constructive criticism that I personally welcome with anything that I do. Take motor cooling jackets is commonly known that the silicon type water coolers or plastic tube type coolers do not work as effectively as aluminium coolers due to the heat dissipation with aluminium.
my ultimate seaking 180 cooling block
Not meaning to upset anyone but offer constructive criticism that I personally welcome with anything that I do. Take motor cooling jackets is commonly known that the silicon type water coolers or plastic tube type coolers do not work as effectively as aluminium coolers due to the heat dissipation with aluminium.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Honestly I'm not really interested in making aby of them. I would make you one since you asked, let me be honest with you tho, it's probably more than you'd want to spend on this but I'd do it for $55 shipped. It's about 3 hours worth of work to make one.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I'm not either. Honestly I took offense to your comment because I put alot of work and time and thought into this thing that someone telling me it isn't going to work as well as your idea kinda sets me off. I'm sure you'd feel the same way. I apologize if I got carried away. I take pride in my work.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I can understand what Martin is getting at, although it's only the top plate that is carbon so it's prolly not gonna make a huge difference.
You could try using an aluminum top plate just to see if it makes any. Or laminate carbon plate over the aluminum top plate for the aesthetic.
Nice job tho Travis. Looks good
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Travis, that looks awsome! I'm sure it's a huge improvement over the original. It would have been cool to run it in it's original form and take a temp reading then run the new one and see how much difference there is.Comment
I can do that. Good idea! I'll leave the stock cooling block on it. Make some passes. Bring in. Check temp. Change block real quick. Try to duplicate my passes. Check temp again. That's the way I will do it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Sent from my iPhone using Tapatalk32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Your right, too much for me...lol. Plus I don't want to pull you away from your fantasm build....now get back to work! LolComment
I like it and think it will work good ! I don't think the carbon will hurt anything as it's on the top side ."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Travis,
I don't think it's necessary to change the carbon plate to aluminum, but it would certainly increase heat transfer, albeit to a relatively small degree.
It's not an effect of dissipation via air though...I think you might be missing the point and perhaps Martin is too.
I'm not going to go further into an unsolicited explanation since you started a thread to show off what you made, not a thread to learn more about heat transfer.
Nice work on the part. It's always more impressive to see something made by hand than it is if it were just purchased from a hobby store, not to mention much more rewarding.Comment
