*** New SeaKing 180 V3 Testing... Could use set up advice
  • msundsd5
    Msundsd Racing/ COE
    • Nov 2013
    • 244
    OKAY OKAY OKAY , what we have all been waiting for...... Testing of the New SeaKing 180esc V3. I grabbed a BlackJack 29 for testing purposes to see how this baby does.
    Set up: BlackJack29, Tacon 4074 2200KV Motor, New SeaKing 180esc V3, M545 Prop, 4s set up 65C 5000mah ( Batteries were 80% Charged )
    If you have suggestion on improving this particular boat in the water please share, however, realize this boat was just sitting on the shelf, I grabbed the new esc's for testing and went to the lake so don't be so hard on me fellas .... LOL...... Also need some prop advice, do you think I should go up based on what you see?
    Painting the Picture: I made 8 full throttle passes, top speed 54mph, about 85 degrees here and humid, I had to hold the phone with my chin so the 1st several passes were shot with the camera facing the ground.... LOL..... however I was able to get a few passes on camera and at the end of the video I show the temps of all the electronics, you be the judge and let me know what you think!
    Just posted..... she's live........ I look forward to touching base with your contact and exchanging info. I appreciate you reaching out...... stay in touch!
    http://youtu.be/P8S0xHbjJX8 ( NEW CLEANER VIDEO THAN THE FIRST )
    Lot Boyz Racing and Marine Team...Get Hype!
    CF Shocker Twin - 93.4mph / CF Daytona Single - 80.2mph
    FG Shocker Single - 98.3mph / Miss Geico 24" Single - 72.3mph
    The esc is hotter than I like my esc to be. When the lvc kicked in, what did it do? Just die or slow down.
    • msundsd5
      Msundsd Racing/ COE
      • Nov 2013
      • 244
      When LVC cut in it brought it to like 50% power....... it was smooth too. Unlike the old SeaKing and Turnigy 180's I didn't have to cut the function off to run the esc so that is an improvement in itself. I'm sure if I put some focus on the set up I could run the esc cooler. Remember, this boat was sitting around with just a motor and receiver in it, I just through a prop on it and the esc for testing.
        I think an x642 prop would work better. Lower your temps and likely go just as fast. That's what I've found on low power, low voltage setups anyway. I picked up 1 mph going from a x642 to a m645 at the expense of other things. (Temps, battery times, extra load, boat handling funny) my geico went faster with an x642 vs this m645 also....but my rivercat picked up. More power. Bigger boat.
        • msundsd5
          Msundsd Racing/ COE
          • Nov 2013
          • 244
          I have a X642 detonged, so I think I will try that next time out this weekend...... Looking to try an X447, M445, X646, and a X448
          • Spartanator
            • 1060
            Good to know since I have not opened mine yet... Does it look like there can be another cooling inlet/outlet added?
              Evidently you haven't been acquainted with prop walk yet. Let me know how those bigger props work out for you lol. That hull prefers a smaller prop. You'll likely burn the esc up with that high kv motor and the bigger props. High kv, low voltage and huge prop on a small hull doesn't usually mix well.
              • urbs00007
                • Jun 2011
                • 826
                what speed controller did you run in the boat previously? did it run 130 degrees?
                • tlandauer
                  • 5666
                  My MG had a Leopard 4082/2200kv with a x642, SK 180V2, temp never went beyond 113F, GPS´s at 53.3mph. Thunder Tiger 5000mah 65c 2x2s ( I have not started to run 4s2p at that time yet) I have been using m545 in lure of m445 on many other applications, the temp is not that different from a M445.
                  How many minutes until LVC kicked in?
                  • iridebikes247
                    • Dec 2011
                    • 1449
                    its waterproofed so it probably has that same stuff covering in the swordfish escs have. really stupid imo, and definitely leads to heat build up. Been meaning to pull the silicone off and do temp testing with and without it.
                    I imagine this esc will be great once the bugs are worked out just hopefully we don't have to make modifications to a newer much more expensive esc, for it to perform like the old. Pretty cool you did this video for us though, i know i've been wondering about this thing lol
                    • rickwess
                      • Apr 2013
                      • 777
                      Looks like you almost wiped out a duck at the 14 second mark. I'm trying to figure out if you saw it when you backed off the throttle a little but decided to gun it away.
                      • msundsd5
                        Msundsd Racing/ COE
                        • Nov 2013
                        • 244
                        Thanks for the post fellas:
                        @kfxguy ............ Actually with this same boat ( had a different paint job ) I ran 59 MPH 6 months ago with an X448 prop on 6s so the larger prop has had no negative impacts thus far, I changed it because it's summer and its warmer but the large prop set up was awesome in the Fall and Winter. As far as heat, the highest temp I had with the larger props were 145 degrees on the esc and the motor was about 130 with batteries in the 115 - 125 range after about 7-8 high speed passes, never blew one of them up. The set up is really for drag racing , making about 6-9 passes.
                        @urbs00007 ..........Previously I ran Seaking 180V2 and Turnigy 180 in this boat and the temps ran just about the same give or take a couple degrees, with this boat and on some of my others , they are set up to make 8-9 passes over a 4 -7 minute timeframe because we drag race them in different classes with the guys I run with.
                        @ tlandauer ......... Your set up looks similar, I'm going to see what the X642 does this weekend and let you know. In regards to the low voltage cutoff, I ran a good 4 minutes starting with a battery that was only 80% charged making circles and full speed passes before it came in. I was really excited about it cause one of my main concerns was that I would have to cut it off like the older versions because they would kick in super early, but I didn't have to, ran it stock out the box and got all that run time on the set up with a boat right off the shelf so I would say it was a successful test. I really like the fact it has LED's to blink RED when low voltage cutoff kicks in so you know EXACTLY what has happened and it also has a LED blink ( I believe green, would have to read again ) for THERMAL shutdown to protect from burning up the esc so I'm liking what I see so far from the new version!
                        @iridebikes247 ........... Yes sir, this video was for the OSE Fam eager to see the esc in action, so I just grabbed a hull that was sitting around, through that bad boy in there and headed to the lake. I know many have been asking and just wanted to give the people what they wanted, that's how we all learn and "get into the know" together. Good Stuff!
                        @rickwess ....... What had happen wassssssssss when I originally road that way I didn't see a duck there, then when I started getting into the throttle I noticed it and let off the throttle coasting until I was clear to get back on it with out putting the poor duck in danger. Definitely don't want PETA thinking I'm trying to harm the ducks, I LOVE DUCKS!!!!
                        This is some good dialogue........ I'm going to play with it a little more this weekend, might put it in another boat and see what it does, change some props, etc. I'll let you all know how it goes. In the meantime , keep sharing your knowledge and thoughts...... Seaking 180 V3 might be on to something special!!!
                        • olwarbirds
                          Magic Smoke Wizard
                          • Oct 2012
                          • 1136
                          Tks for info...sure hope Hobbywing does a higher Voltage soon...we need something to replace the black hole the loss of castle marine esc's has created. Looking forward to more ..... DJ
                          • Livewire121
                            Fast Electric Adict!!
                            • Jul 2012
                            • 317
                            Those ecs's are already available such as MGM Compro, Modellbau-Regler, YGE, and Etti to name a few. IMO castle esc's weren't that great to begin with, I've seen two blow up on the bench, die from getting wet, and die due to vibration. The last one died while trying to retrieve the logged data.
                            HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
                            • ray schrauwen
                              • 9475
                              They do, it's just a 130/180 amp esc. The V3 has a higher Burst rate, 720Amps.
