genesis bacardi silver help, new tp power 4050 1510kv and seaking 180 timing?
  • Shane Lewis
    • Apr 2014
    • 381
    What timing should I set this new motor and esc at, I use 2s 5500 65c batts from john the batt guy. I also have a 3s 4500mah trinity batt, can this be used with a 2s batt for A 5s? not sure about the whole 4s and 5s. This is a monster of a motor let me know what you guys think, I also plan to use the stock 2075 motor that came out of this in another boat, another seaking esc be good for that as well?
  • Shane Lewis
    • Apr 2014
    • 381
    please dont everyone respond at once, hopefully a junior member will get responses as much as everyone else. 1510 Kv/rpm per volt 8D so Im thinking 3 degrees timing????
    • martin
      • 2887
      Yes that is a D wind motor so 3.75 degrees on a Seaking 180a, re 2s & 3s in series to make 5s is ok but both batteries need to be the same capacity & same c rating.
      • grsboats
        • Jul 2012
        • 975
        3,75 is ok and what kind of connector are you using? Gill
        GO FAST AND TURN RIGHT !
        www.grsboats.com.br
        • ezhitz
          • Aug 2009
          • 428
          Looking at your motor picture make sure you put some shrink tubing on your bullet connectors before you run it or you will short out your esc and motor.
          :canada
          • grsboats
            • Jul 2012
            • 975
            That's why I asked him!Gill
            www.grsboats.com.br
            • Shane Lewis
              • Apr 2014
              • 381
              There 5.5 castle bullit connectors with deans on the batts. I just put some shrink wrap on those conn last night but for the need to be completely covered? I set the timing at 3.75 last night as well. If I'm running 4s I just put 2 in the second item when programming for 2 cell batts up to 5 cell? So I need 3s 5500 45-65c if I have those numbers in a 2s?
              • martin
                • 2887
                Get rid of the Deans plugs completely & replace with 5.5 bullets.
