seaking/turnigy 180 smoked on 2nd run...
  • shartinspartin
    • Aug 2013
    • 257
    I finally got to test out my seaking/t-180. First run went perfect. Had voltage sensors and temp sensors running from my new fs-it4 rx. Never saw temps over 70 degrees f. Hit lvd came in and put her on the stand. Ran my motley crew for a pack and it died on the lake. I then went back to my spartan in hopes of saving my mc. Plugged in the first 3s pack then the 2nd. As I plugged in the last bullet, smoke instantly started pouring out of the esc with an unforgettable smell. I instantly unplugged it and hopped in the 40 degree water to get my mc =(
    I was running this in a spartan and it mightve gotten wet... Maybe maybe not, im unsure. I thought this esc was waterproof though?
    I had the timing set to 0 i think and I found out that the turnigy 4082 1500 kv should be ran at 15 degrees. Could that have caused the problem?
  • kendt
    • Jul 2011
    • 557
    Timing wouldnt cause it to blow when you plug it in. It would show up when you are running. Very few if any esc are 100% WP so if it did get wet that could def cause an instant short.The problem also may have happened at the end of the run when you thought it was the lvc. I have two of them that have been nothing but headaches. It could be that it was just a dud.
    • lenny
      • Sep 2010
      • 4294
      Post some pictures of the setup and the packs that you used in the hull like it was rtr,
      Also what prop did you use and how long did it run ?
      How was it running before lvc kicked in, Wet, Dry, Speeds, Have any video's ?
      ? ONLY IF THEY WORK
      • shartinspartin
        • Aug 2013
        • 257
        yes it couldve... well it probably got wet... i was using either spc, g-force, or zippy lipos. I know when the smoke happened i was using 5000 mah 40c 3s g-force lipos. I used the prop Ive always used... the kintec cnc one thats like stock. It was running fine. Kept up with the stock spartan on 6s still... I cant remember the run time... Maybe 5 min
        • shartinspartin
          • Aug 2013
          • 257
          Hey guys. So I went to take a video for hk customer service. The esc was working normal. I even took it to a pond and ran a pack thru it. WTH?
          Can someone explain this to me?
          • Wetter
            • Aug 2013
            • 241
            Puff the magic dragon? ?
            that's wild i wish i knew.
            some one here has had to of gone through this to chime in with some admirable knowledge.
            hopefully it will last.
            have you tried programming the esc to see if it takes a new command?
            • shartinspartin
              • Aug 2013
              • 257
              No i havent
              • jkr
                FE Addiction
                • 568
                Are you sure the smoke came from the esc?
                What connectors you use on motor-esc-lipo?
                • jaike5
                  • Dec 2011
                  • 561
                  Once again somebody is going out after a toy boat, in fridgid water no less ....WTF! Fishing pole with a pepsi ball, wait for the wind, retrieve boat.
                  • shartinspartin
                    • Aug 2013
                    • 257
                    It was like 5 ft out.... Im not worried
                    • shartinspartin
                      • Aug 2013
                      • 257
                      im using 5.5 mm bullets. Yes the smoke smelled like burnt esc
                        Two words. Recovery boat! Why do you not have one? Huh? Its worth its weight in gold. Especially when the water is that cold.
                        I had a turnigy esc smoke on me like that and start working again. I definately don't trust it. If I do use it again I will have a recovery with me so no worries. Hopefully it doesnt catch fire lol.
                        • jkr
                          FE Addiction
                          • 568
                          Do you use external pack to power the reciever or the bec from the esc?
                          I'm curius to know how this happen and after it works lke nothink happened.
                          • shartinspartin
                            • Aug 2013
                            • 257
                            I had an inflatable boat with me. I popped it jumping in it. I figured since i was already wet I might as well go the extra yard and get my boat
                            • shartinspartin
                              • Aug 2013
                              • 257
                              When it smoked did it get wet?
