Is a 120amp esc enough esc for a 25 inch delta force v hull running a 4074 2200kv on 4s? I will be running somewhere between a 440-444 prop for this
120amp seaking with a 4074
Ya that motors way to big for the hull.
120A wont work, 180A.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP) -
Yes,
I am running that motor and a t120a esc on 4s and a x646/3 prop in a 36"PB Shockwave,
Modded to FE.
I just had to add three 1000ur caps to the esc to keep the temps down on them,
Runs very nice at 42 mph and about 6 minutes of run time on 2x4s 30c 3600mah packs.Comment
Lenny thanks for the input, I have a stiletto with a 120 on5s but it's on a stock proboat 1800kv motor and with a 442 prop consistently get 56 + mph, it does have a lawless 3.5 though, which makes quite a difference compared to the stock outdrive.Comment
Have any videos of it running ?Comment
As long as you stick to 4s and don't go big on the prop it will be fine.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
Devo.
That T120 will easily spin that motor in the 25" delta with those props. I've run that combination in hulls up to 32"
Two things though. Add a couple of capacitors for insursance. And get yourself an X440/3 prop rather than going up to a 44mm size. The boat handles much better in my opinion with three blade props. Less torque roll than with bigger diameter props. More stable in the corners too.See the danger. THEN DO IT ANYWAY!!!
