Hey just curious who runs the seaking 180 on 6s and how many runs you've given it. I am running 1600kv twin leopard/twin seaking combo, temps stay really low. I consider myself a sport boater and have been running on 5s1p per side and I feel like this is a solid setup. Will jumping up to 6s put a lot more strain on my esc? Thanks guys.
seaking 180 6s?
Tags: None
I'm running a Jae Fe with 4082 2000kv on 6S and with a little mod on this esc you can run cool..40C.GillGO FAST AND TURN RIGHT !
www.grsboats.com.brComment
I run T180's on 6s with the bec in operation.
The only issue you may encounter is the pre-mature LVC, set it at 2.8v or turn it off and time your runs.................start with a 3 minute run then check capacity when you charge back up. On second thought, if you run a big prop in high heat, they have been known to thermal as well, keep is mild in August.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
My boat is a rigger made for saw and this is the simple mod .GillAttached FilesGO FAST AND TURN RIGHT !
I modded one too, had some aluminum "L" stock handy so I used it. The larger shape of the aluminum pieces acts as a heatsink as well. Yours looks alot "prettier" than mine.Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Hey just curious who runs the seaking 180 on 6s and how many runs you've given it. I am running 1600kv twin leopard/twin seaking combo, temps stay really low. I consider myself a sport boater and have been running on 5s1p per side and I feel like this is a solid setup. Will jumping up to 6s put a lot more strain on my esc? Thanks guys.Comment
