Leopard 4082/Seaking 180 OSE Combo, good for FC 37" Daytona Cat?
  • Checkmateguy01
    • May 2009
    • 376
    Just browsing thru OSE trying to figure out what motor and ESC to power the FighterCat 37" Daytona hull i just bought and came accross the 4082/T180 1550KV Combo OSE has, say's for 32-40" inch hulls and 6s friendly. Anyways before i buy, gotta bunch of questions. First, what kinda speed would you see with that 1550KV motor on just 4s? 40 mph give or take?? Also, could that set-up be run on two 7-cell NIMH's from time to time with out destroying/over-working/over-heating the nickle batts.?? I like that it's ready to install, that would save some time, not that i'm in any hurry tho, winter is just about here! So if that is not a good motor/esc combo for my goals, what would work better? I've also been looking the Leopard 4074 1800kv motor, or the 3674 1700kv leopard. Again, my goals are 30's on (2) 7-cell NIMH's, around 40 on 4s, and 6s compatable if that is also possible. One last thing (maybe problem), i intend to use Traxxas connectors so i can run all batteries between the Daytona and Spartan, then i don't have to either cut up my batteries i already have, or cut up the Spartan and possibly void the warrenty. Thanks, i always appretiate the help you get around here!
  • Boaterguy
    • 1760
    It's either the 4074 or 4082 that people put in the genesis all the time, it is a 6S setup at 1550kv and 4S/5S on the 1800kv.
    7S nimh will only give about 8.4 volts, not even comparable to the 22.2V of a 6S battery, you could run it, but it might not even get on plane, perhaps on 14 cells, but it would put a big strain on the nimh's.
    • Checkmateguy01
      • May 2009
      • 376
      No, no, i would be running a total of 14 cells NIMH's, two 7 cell packs in series (16.8v), not just one 7 cell pack, lol i do know that much! Just to clarify!
      • Boaterguy
        • 1760
        well.. i was gonna say...
        It would put a load on the cells though
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          This is coming from someone with experience with the 37" cat. Run the 180 speedo with the Leopard 1550kv combo on 6s. Use an Octura X445 prop to start with the strut at neutral. Use an external BEC or a reciever pack. You ll get low 60's for speed and cool temps with plenty of room to prop up if you want a few more mph. Someone that doesnt have this boat or powertrain cannot comment on what will work. Sending pm.
          • video200
            • 837
            i dont think that the 4082 would do you much good on 4S or your nihm batteries and i dubt youwil get 40 mph out of it
            if your options are 4s and 2 nihm packs i think you would be much better off with a 4074 2000kv,4074 2200kv or the 4082 2200kv.
            i can only speak for the 4074 2000 kv in the daytona\genesis cat and that works great on 4S and M645 witch gives speeds around mid 50`s.
            klaus
            • Checkmateguy01
              • May 2009
              • 376
              klaus
              Thats moving pretty good on 4s!! But can it run NIMH's with out them ?? I guess i need a little education here since my view/desire to run 14 cell NIMH's all the way up to 6s at some point is a little optomistic since that's "technically" how the Traxxas Spartan is supposed to work (i know it really doesn't but). So i'm thinking i need to stay in the 1600KV-1800KV range to achieve the 30's on NIMH's and 40's -50's on 4s-6s, since that's what is in the Spartan. 4s and 14 cell NIMH's is what i'm gonna start with, 6s is a long way off and if i can't have that right now, no big deal. When i'm fun running at the lake house 50's mph is way overkill which is why i want to run the NIMH's. I have a 1898KV motor in my 32" Dumas mono, i've run that on 6 cell NIMH's (12 cell total) with an Etti 150 ESC and not had any issues, batts get hot but not extreme. Is it higher KV motors for "lesser" batteries, or lower KV motors for "lesser" batteries (does that make sense?)? I know it's funny, most people are looking for "all out how fast can i go", and i'm looking to slow down lol!
              • jj2003
                HIGH VOLTAGE ADDICT!
                • May 2011
                • 1501
                You could use 2 3s packs in series for 6s, drop them in the sponses for plenty of room. I'm running twin Turnigy 1400's on 6's and have yet to hit 50 but I'm close. I'm still fine tuning my hull and transmitter settings to get there, but it's within reach. As Larry stated, the 1550 combo is a great setup. Anything higher in kv on 6's and your pushing the limits of the 180a. I have two builds in the build section and numerous video's in the video section for some views. The single setup in my opinion is much more stable than the twin and a fun boat to drive in nice calm conditions. My choice to do twins is from being on Lake Erie and I needed something with a little more umph to handle the surface chop. To light and she's airborn and thats almost unavoidable here. My excess weight keeps her in the water( with a few exception's he he) and she'll handle some chop which is almost always pesent.
                "If guns cause crime, all of mine are defective"
                45"Speedfreek
                , Fightercat #068 ​, MyYoutube Vids
                • Checkmateguy01
                  • May 2009
                  • 376
                  Yeah you definatly know what it's like running on lake water!! Erie is much bigger than what i run on, my lake is about 21 miles long 1/2 or so mile wide average. But i'm down in a small cove area, lake gets "calm" in the evenings but i have lot's of dock, boats, and lifts pertruding out in the lake, for saftey reasons i'd perfer not to go much over the 30's to 40. The SV27 and Spartan proved to be fast enough for me to be fun and draw a croud anytime i run them, but i love cat hulls and wanted something a bit bigger than the Mystic/Gieco/Motely Crew, hence the Daytona/Genesis. The NiMH's are nice for the added weight to keep the boats on the water, that's why i like them! I've been looking at some of the new RTR's and what they are running, even tho they are slightly smaller boats the Aquacraft and ProBoats are mostly running 1800KV motors and are 4s and NIMH campatable with only 60A ESC's. The T180 is probably overkill but shouldn't be a problem would it? I'm gonna forget about 6s right now, just concentrate on a good NIMH-4s motor/ESC.
                  • jj2003
                    • May 2011
                    • 1501
                    The 180 will provide you room to grow. Use the nihm's, then look at some 2s 5000mah 30-40c rated packs. You'll love the speed pickup and still be below the threshold. They are quite cheap. Even used I'm seeing them for 20-30 each in various forms. Look on http://www.rcgroups.com/aircraft-ele...fixid=For_Sale. There wa a gentleman I spoke to about some new venom packs for $85 for the pair. They were a lower c rating, but for $40 each it was a good price. There are more as well so keep looking. Youll find what you need.
                    45"Speedfreek
                    • jj2003
                      • May 2011
                      • 1501
                      Or bump the nihm's to 10.8 and see an improvement also! http://www.hobbypartz.com/98p-5000-1...flat-hump.html Hobbyparts has a huge sale on lipo's right now too!
                      45"Speedfreek
                      • Gimp
                        I am the Stig
                        • Jan 2011
                        • 547
                        Heck, for that price you might as well get the 4s setup with 2x2s http://www.hobbypartz.com/98p-40c-50...se-direct.html
                        -Fighter Cat Racing-
                        • jj2003
                          • May 2011
                          • 1501
                          Exactly! I'm not sure but I think he may be trying to avoid lipo's for the time being and just use the batteries from his spartan for cost.
                          45"Speedfreek
                          • Checkmateguy01
                            • May 2009
                            • 376
                            Thats what i was thinking!! Room to grow with the T180. So should i go with the 1800KV 4074 or the 1550KV 4082?
                            Nope not avoiding lipos for cost, actually i just bought (a couple months ago now) a lipo ready charger and will be gettin a pair of 2s lipos for next season for sure. I plan on setting the boat up with the batteries in series. I want to run the NIMH's also for a few reasons, keep the speed down at the lake, weight, and becuase i have a couple good sets of 7 cells and want to keep using them!
                            • jj2003
                              • May 2011
                              • 1501
                              All good reasons! I would run the 1800kv. The 180 is good on those and on 4s still within its limits.
                              45"Speedfreek
