New Seaking 180A-R ESC and Leopard 4082 1600Kv
  • Bigbore
    • Sep 2010
    • 168
    I have been running a Titan 29" with 5S2P Zippy LiPo 5000mAh.
    I've been using and external BEC and added a water pump for continuous cooling but last week due high temperature of water and air I was able to burn the Lepard 4074 2000Kv. My fault was to run for more than 2 minutes continuosly without checking the temperatures with an X440/3 prop.
    The Seaking 180A, that I've been running, was burnt too.
    So, I have ordered this new stuff.
    Anybody knows this 180A Seaking? It has a label 180A-R, what doest that mean?
    This is the motor and I like the back plate where the cable exits and the holes to let some air to cool the winds, it's different from my previous 4074.
    Then I would suggest to the other owner of the Seaking 180A ESC to seal this spot, in my burnt ESC some water passed that spot and I know it from the little corrosion I found inside.
    On the other side there is some kind of stuck rubber, this stuff is from the factory.
    Uploaded with ImageShack.us
  • JackBlack26
    • May 2007
    • 905
    The R is probably for the added resisters. They usually only come with 3. That one appears to have 5.
    It's cool that Leopard added those cooling holes. Should keep thing a bit cooler.
    As far as the open space between the two cooling ports, there have been plenty of people that use different materials to cool that area as well. I don't think water getting in there is an issue.
    • Rumdog
      • 6453
      Not a 5s motor. That's why it failed.
      • Boaterguy
        • 1760
        you mean caps, the things sticking off the side?
        • iamandrew
          • 577
          you sure thats not a 5S motor?
          everything ive found on the net shows that 2000 or 2200kv motors that size can handle 5S.
          theres new buggy motors like the one in the HPI Vorza which is 2200Kv and runs 2 3S packs in series
          • golfito
            • Sep 2011
            • 296
            hello:
            I can ask if I add capacitors to your drive? I think 35v capacitors are
            1000 uF.
            Connect them in parallel connection?. To achieve 5000uF? . That achieves improved performance or increased security achieved with this modification.
            Excuse me please so many questions.
            Regards, Hernan
            • Boaterguy
              • 1760
              not all 35V capacitors are 1000uF, but you can get some
              they should be connected in parallel, it will more be a safety feature than improving performance. capacitors are there to "compensate" for the voltage drop when the cells are under load.
              • Rumdog
                • 6453
                boats and cars... not the same.
                • Bigbore
                  • Sep 2010
                  • 168
                  Originally posted by golfito
                  hello:
                  1000 uF.
                  Regards, Hernan
                  Yes the caps are parallel connected and are 35V 1000uF like these: http://www.offshoreelectrics.com/pro...k-cap-35v-1000
                  I've ordered also this Etti ESC Capacitor Bank: http://www.offshoreelectrics.com/pro...d=etti-e035-lv
                  Because the stock caps are not reliable, the little wire connection between cap and board tends to break.
                  • Bigbore
                    • Sep 2010
                    • 168
                    You're right! I wanted to try the same ..... and learned by smoking that I need a lower Kv so I'm installing the 1600Kv.
                    • iamandrew
                      • 577
                      No im going to have to disagree with you guys in regards to the "OH thats not a 5S motor" comments
                      A boat that size with that KV motor should handle 5 S packs no problem
                      A lot of you guys seem to think that shoving 10S packs in a boat on a 500kv motor is the solution, the only problem you seem to be forgetting is that all these packs are adding weight, so you then stick props that are either too big or too much pitch, then complain about snapping the drive shaft, or crap handling etc or your 2 minute run time.
                      In regards to the actual reason this guys stuff has blown out, is probably due to not enough water cooling. a water pump should not be needed, and if anything has probably jammed its impeller or somthing like that, thus slowing down the water passing through the components.
                      • Diesel6401
                        Memento Vivere
                        • 4204
                        I disagree to your disagree a 2000-2200 kv motor on 5s in boating is a fail as you have just seen. reason being is that added amp draw at higher rpm. Watercooling is NOT going to prevent or stop the amp/ddraw surges which are created by the higher amount of rpms. 500kv motors have there place in very VERY large hulls and in those veryVERY large hulls the extra weight is actually needed to keep the hull in the water at higher speeds. Now the size of the hull would be mighty big for a 500kv motor like 50+", in which the cell count weight would not matter at all. Rpm management is very important in boating. Go see how many guys have blown there setups running 1515 1y motor on 5s and 6s going 50+mph there is a lot of water cooling but yet the setups are still failing why? because of the amp spikes!
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          +1 on that, too many guys thinking "i run 6s on my erevo with not problems why does it fail in boating" smh!
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • martin
                            • 2887
                            +2, To many look at their esc spec & because it says 6s or 7s think its safe to use in a boat on say 6s. Unless its something like a 180amp esc its not safe to use 6s in a boat. Amp draws go out the window in boats compared with cars.
                            • Boaterguy
                              • 1760
                              that's why boat ESC's are harder to find, and they are much more expensive, then say an 80A car esc.
