Yeah I set them both to 3.75, the lowest before zero.
SeaKing 180 ESC...extra cooling.
Believe it or not I get tons of water shooting out the hull discharges. Might just depend on the hull and where you have them mounted.
And the "custom cooling" on these T180s works awsome.
The temps went from 125 one one and 151 on the other down to 100 and 120. Major improvement!Comment
still interesting that one is 20* higher?
maybe it a prop issue....NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
yes, its completely hollow down the middle. Wasted space. The cooling works great. Knocked temps down by 25-30 degrees.Comment
Chris did you program the esc's with the Tx or do you have a program card?FE BOATING: Less like a hobby and more like an addiction!Comment
With the TX. I put the timing at 3.7 and the LVC at 3.0 on both. But I think I'm going to raise the LVC to 3.7 volts per cell.Comment
Timing should be fine with 5deg being max on a "d" wind motor. Is there any way u used a different Tx to program one of them? I think I did this before and maybe it was the different throttle calibration between two Tx's.FE BOATING: Less like a hobby and more like an addiction!Comment
A common issue with twins is how the two motors work in turns. The inside motor has to work harder than the outside motor, and the tighter the turns the more the inside motors has to work. This is likely why one ESC is hotter by 20*.
is it the same ESC that gets warmer..? or the location it's installed ( L/R) ?
Have you tried swapping L-R ?Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Ironically the same motor with the hot ESC is the same one I lost the prop and shaft on. Unrelated I'm sure.
I'm replacing the stupid solder in stub shafts and flex with the one piece Hughey shafts. I'm a little pissed I lost a shaft and 70 dollar prop just as I was getting her dialed in.
I think I'll pat myself on the back....LOLComment
possible bind on the hotter side?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
