BEC not working on Hobbywing/Seaking ESC?
  • JCAustralia
    • Jul 2008
    • 304
    Hi guys
    I just completed the maiden voyage of my Mean Machine.
    The motor I used is a Feisuda amp and the ESC is a 120 amp Hobbywing/Seaking ESC.
    After like 3-4 mins the boat just stopped. Waited for like 15 minutes and there was no wind and the boat just stayed in the middle of the lake.....
    So I swan in the lake to pick up the boat..... Was pretty disappointed to have this problem on the maiden voyage of my newly completed Mean Machine...
    Did a number of test at home to determine what is the problem.....
    It looks that its the BEC of the ESC that is not working. When I power the receiver with an external power source everything is fine. Thanks god.....
    A friend of mine told me that the Hobbywing/Seaking ESC ofter have the BEC behaving funny or just die.....
    Has anyone been having similar experience with their BEC from this manufacturer's product?
  • Rumdog
    • 6453
    What is your setup?
    I do ot use a internal bec on any esc over 3s.
    • Doby
      KANADA RULES!
      • 7280
      I've had it happen......plug in a receiver pack and you should be good to go!
      Grand River Marine Modellers
      • JCAustralia
        • Jul 2008
        • 304
        my set up is
        Hobbywing/Seaking 120amp
        Feisuda with inbuilt water cooling (the chinese anodized purple one)
        Two 2S Turniguy Lipo battery
        Plastic black propeller from Ebay
        Why don't you use an internal BEC over 3S? Will that fry the receiver?
        Mine looks that its the internal BEC that die. The ESC still works with and external power supply. Thank god
        I was so upset at that time and was even considering selling the boat and get a nice brush motor with an Eco boat...... They are so reliable and fun......
        Anyway I am sticking with brushless for the speed and thrill factor
        • properchopper
          rcgoatbuild@snotmail.com
          • 6968
          Happened to me also. Others have reported this as well. Rx pack or external UBEC & git' er done
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            Yep. I have one that finally died. It died while programming it. I now use a UBEC and FWIW it does not run any cooler with it.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              It's interesting how little information there is on larger servo's and their amp draw.
              Some items of note;
              - If the servo is pushing against the rudder at speed or binding it might pull it's maximum amperage
              - The Hobbywing BEC is only 3.5a, most servo's are rated at up to 7 amps.
              I've had the BEC's fail, BUT only when I was running servo's that are rated to draw more than 5 amps. Might be coincidence. Might not.
              • properchopper
                • 6968
                Some items of note;
                Good points ! Makes me wonder what safety threshold I have using the internal BEC's on my boats. Just so you know, I've had at least a half dozen stand-alone CC BEC's fail - either die altogether or pass battery voltage-taking out Rx's and servos. It's all internal BEC's for me now.While I can't find out the current draw on the EXI D226-F servo I run in several boats, the servo, rated at 185 oz/in cranks a huge rudder on my 9.5 pound Cyberstorm which corners hard enough to bend rudder brackets while being supplied with the internal CC240LV BEC. My findings are consistant with Mr. Mopars in that I'm not finding excessive heat buildup in any of my SC's [AQ UL-1's, Turnigy 120's, Turnigy 180's and the CC240]. Bear in mind that these are all 4S setups.
                I recall seing a recent post explaining that early internal BEC designs did create excessive heat, but later switching designs don't have this characteristic. The only internal bec failure I've experienced recently was a Seaking 180 which I believe suffered from water intrusion. ( The two I'm currently running have been siliconed).
