seaking 180 esc not working...HELP!!
  • britscoot
    • 656
    new esc and its not doing its thing.
    all i'm getting is a beep beep etc and a red flashing light.
    steering is working but no throttle.
    freshly charged battery and i have the program card.
    i am stumped.
    thanks in advance
    ian
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Did you calibrate with your radio?
    Canada
    • britscoot
      • 656
      if you mean holding throttle on full while connecting power, yes.
      I have even tried a different motor.I have other smaller seakings and this is the first problem
      i've had.
      I cant get the program card to work with either.
      I really appreciate your help.
      • m4a1usr
        Fast Electric Addict
        • 2038
        What battery are you using? 2S? 6S?
        John
        Change is the one Constant
        • britscoot
          • 656
          4s lipo fully charged.
          I have the dx3 tx.
          The 180 is beeping and the motor is twitching as it beeps.
          If that makes sense....lol
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            Yes that usually happens when you connect power but have no radio signal. When holding the throttle open on start up are you returning to neutral while its still beeping? I'm going to assume your using the internal BEC, which means power is getting through it and powering your reciever. Try re-binding your tx to you rx and try setting the throttle perameters again.
            BTW make double sure your esc is plugged into the correct port and the right way into your rx. Iv'e made that mistake a few times myself.
            • britscoot
              • 656
              i've tried everything i normally do.
              re bind etc.
              I have installed new esc's before bit this is new problem for me.
              The red light on the esc flashes and the motor twitches even when its not plugged in to the rx.
              I have also tried another rx.
              Looks like its a paper weight or is the 180 different to my 120 and 35amp seakings?
              thanks again
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1679
                re bind etc.
                thanks again
                Did you try reversing the throttle channel?
                • electric
                  • May 2008
                  • 1744
                  Try this. I bet that is it.
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1598
                    I had a similar problem one time when my esc was programmed for a higher voltage. If the input voltage is not high enough it won't do anything but blink blink blink.
                    FE BOATING: Less like a hobby and more like an addiction!
                    • sailr
                      • Nov 2007
                      • 6927
                      Don't use the auto-detect setting for lipos. Manually set it for the number of cells you are using.
                      Mini Cat Racing USA
                      www.minicatracingusa.com
                      • britscoot
                        • 656
                        all i have is a red flashing light and the motor twitches.
                        I tried using the program card but got nothing.
                        reversed the tx etc.
                        this really sux.
                        • britscoot
                          • 656
                          if its not working with the program card it must be f'ed?
                          I just hooked up the card to my seaking 120 no problem.
                          what are your thoughts?
                          • sailr
                            • Nov 2007
                            • 6927
                            The motor twitches because that is where the sound comes from!
                            Mini Cat Racing USA
                            • britscoot
                              • 656
                              i just tried different voltage and still nothing.
                              I still dont understand why it wont work with the program card.
                              Hobbywings website isnt really helpful either.
                              I emailed them once regarding another esc problem i was having and got no response.
                              Guess you get what you pay for.
