Actually, as soon as I said it, I realized that it wasn't very cool or fair to refer to it that way. [I'm running the Tactic Tx/Rx in six boats while my Fasst is gathering dust on the shelf.] The only two beefs I have with it is : the trim pots are somewhat non-linear, and without model-memory I need to fuss with the trims every time I put a boat in the water- I usually bring six boats to the lake. I have had 3 Rx's fail, but Tower has warranteed them every time. It's very good for the money, obviously !
Seaking 180 first run report
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /Mono -
LOL you got to watch what you say on camera dude.....lol just ask Obama
when you say rx failure ..they just quit, nothing?
Actually, as soon as I said it, I realized that it wasn't very cool or fair to refer to it that way. [I'm running the Tactic Tx/Rx in six boats while my Fasst is gathering dust on the shelf.] The only two beefs I have with it is : the trim pots are somewhat non-linear, and without model-memory I need to fuss with the trims every time I put a boat in the water- I usually bring six boats to the lake. I have had 3 Rx's fail, but Tower has warranteed them every time. It's very good for the money, obviously !SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
Actually, as soon as I said it, I realized that it wasn't very cool or fair to refer to it that way. [I'm running the Tactic Tx/Rx in six boats while my Fasst is gathering dust on the shelf.] The only two beefs I have with it is : the trim pots are somewhat non-linear, and without model-memory I need to fuss with the trims every time I put a boat in the water- I usually bring six boats to the lake. I have had 3 Rx's fail, but Tower has warranteed them every time. It's very good for the money, obviously !][ And no, it didn't help ]
Attached FilesLast edited by properchopper; 11-21-2009, 11:06 AM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
One caught fire and melted. One Sizzled. One Quit & smelled funny. In all cases I tend to believe that the power supplied by the CC BEC I was using was too much for the Rx - even 'tho I programmed the BEC to 5.8 volts, which is what the UL-1 SC puts out and the Tactic comes with the RTR UL-1. I'm now using the internal BEC's with all but one Tactic-equipped boats. I also suspect some water intrusion could have contributed to the failures even 'tho I corrosion-X'd them.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
I now enclose the Rx's in these plastic boxes; one is from Office Depot-.99 cents, the other is a box a servo came in. Won't survive submersion, but keeps the spray/slosh off the Rx. Never had much luck with balloons. Since these failures, I've fixed all the small leaks & all boats are now bone-dry.Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
A bone dry boat is the best solution. I like to use dp270. That stuff is awsome!* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
The prog box HC is selling is for cars and the Marine ESC won't even recognize most of the features.
$89 +8+20 = $117 and the prog box will be the wrong one.
I believe I priced mine fairly. No matter, they are all gone and thanks to everyone!
The Turnigy-labeled SC on HK's site seems identical to the Seaking, BUT the HK programming card that they show only has Running Mode, Drag Brake Force, and LVC. The Hobbywing-branded card that I got with my SC from Jim has :
Running mode, Cell count, LVC, and a choice of 8 timing values. Mo' better !Mini Cat Racing USA
plus the fact when they all start smoking we dont have to fuss with china,,,,we can rent a bus and all just show up in your front yard.....
I agree about the bus !!2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
:::::::::::::::. It's NEVER fast enough! .:::::::::::::::Comment
Eeeeeeeeeek! Guess I'm gonna need some security!
Mini Cat Racing USA
