I was working on a couple of Swordfish X+ 200A ESC's today.
The water inlets were only .095" inside, So I took some measurements
To see if a piece of 5/32" ID. brass tubing would make it better.
It will fit.
So I drilled out the ESC to 5/32" all the way through, then I used a 3/16" reamer to open up the ends to 7/16" deep.
Every thing would fit like a charm.
This would make the water flow 2.8 times more then before.
I then had to come up with a way to make the tubing secure so it would not just slid off.
Even with a wire tie. I still needed a bump on the end to stop it from sliding.
Larry
It will fit.
Larry
