Swordfish 200A Cooling?
  • DanS1
    • Jul 2018
    • 12
    I'm a first-time builder and am using a SwordfishX 200A ESC. It has two cooling channels, one right and one left. Can I simply loop the output of the right channel back into the left channel, or will this provide insufficient cooling on the left side? I can use Y splitters to split the input cool water, then combine the exhaust water if need be, though real estate is getting short in the ESC mounting location. I would appreciate any advice -
  • 30nitro
    • Feb 2018
    • 330
    Yes...you can loop the left to the right....cool in on the left hot out on the right...or vice versa.... not good to use y splitters.... use separate water intakes for motor and ESC...if at all possible.... Hope this helps ya....
    • DanS1
      • Jul 2018
      • 12
      Thanks very much. Was hoping I could - and I do have separate water intakes for motor and ESC.
