Hifei issue 4,11
  • grsboats
    • Jul 2012
    • 975
    Hifei issue 4,11
    Today we did some saw tests using a TPpower motor 4050 connected to a 300 lite esc.Everything worked great ( no running issues) but when we decided to open the Hifei 4.11 software there is no way to know the recorded data.
    Esc connects to computer,we can open the device and go to the data recorded window,choose the correct number poles of motor(4) and click to download data that goes good (transfer runs ok) till we try to open the new window so we have a running error message and windows(10) close the whole program.
    I really don't know the real problem so let me know what do you think.
    Thanks
    Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
  • CraigP
    • May 2017
    • 1464
    Try right-clicking on the program icon for the heifi software. There is a compatibility command in there. Try setting it to run on Windows 7 system. You may need to use XP SP2 as well. I had the same issue until I got the right operating system running on it. Choosing this then executes the program under selected system as if you had that operating system actually loaded. I hope that helps!
    • trigger
      • Sep 2013
      • 853
      My newer model 300, runs 6.xx software but had the same issue. Right click on the program and run as administrator, that solved it for me.
      • grsboats
        • Jul 2012
        • 975
        Thanks I will get a try and let you know...on my old laptop with Vista I had no issues.
        Gill
        www.grsboats.com.br
        • grsboats
          • Jul 2012
          • 975
          NICE its working......Thanks a lot!....a sample of those tests.
          Cheers
          Gill
          www.grsboats.com.br
          • Old School
            • Aug 2017
            • 686
            I had a recent issue with a newly purchased Swordfish Pro+ 200 amp ESC. Would not open on version 4 so as I had already downloaded version 5.02, I tried that and the programme ran normally.
            • grsboats
              • Jul 2012
              • 975
              Thanks oldschool....I did what trigger wrote....ran it as administrator and worked.
              Cheers to all
              www.grsboats.com.br
              • trigger
                • Sep 2013
                • 853
                Sweet, glad you got it.
                • Gofast12s
                  • Jun 2018
                  • 19
                  I use an old XP laptop my Windows 7 don't work well at all RUN XP.....
                  • nitrous8e
                    • Dec 2011
                    • 30
                    tried all of the above still a no go + a time out error ordered a new program cable see if that helps
                    • Raydee
                      • May 2007
                      • 1603
                      Had the same happen to me, ordered a new USB cable and that fixed it.
                      Team Liquid Dash
                      • CraigP
                        • May 2017
                        • 1464
                        First, you have to be sure you are using the right comm port. Need to go to “Hardware Devices” on your computer. Plug the cable in when attached to your ESC. You should see the Device List refresh, note what pops up in the USB section. It will say what port that is. Use that port number in the Heifi program. If you plug it into a different USB port on your computer, the port number will change, so use the same port.
