Chargrilled Swordfish
  • Rocstar
    Joel Mertz
    • Jun 2012
    • 1509
    #31
    Originally posted by kfxguy
    Well this one was black like the one above but a little worse, but I tested it like this.... (pretty obvious when you see it lol)
    Letting the smoke out is one way to test it, lol. Hopefully it doesn't damage your controller.
    • Make-a-Wake
      FE Rules!
      • 5557
      #32
      Hey Terry, just think of it this way. You have the distinction of being the first man to toast a motor in RC boat history!
      • flraptor07
        • Aug 2013
        • 2451
        #33
        Travis, I'd think testing it that way would be a little rough on your tester....
          That's why I'm using a mamba monster. It has protection. I shorted the wires on it the other day by accident. ... it was alot more zap than I expected. But the esc shuts down. Wish all our boat esc's would do the same
          • ray schrauwen
            • 9471
            #35
            A motor with an 8mm shaft might help if the rotor is vibrating at full rpm. HET, NEU, and TP 4070 motors have 8mm shafts.
            Nortavlag Bulc
              Big shafts are always better
              Muhahahaha!
              • flraptor07
                • Aug 2013
                • 2451
                #37
                Muhahahaha!
                Boat Motors, Travis we're talking about BOAT MOTORS!!!
                • keithbradley
                  • 3663
                  #38
                  Many of them have the same protection. The Castle Ice air and marine ESCs both had/have over current protection. MGM and Schulze ESCs have safeties in place for reversed polarity, shorting, locked rotor, and motor leads falling off. However they will all tell you that any of these situation can still fry the ESC, regardless of protections within the ESC.
                  When I was using Castle Ice air ESCs in boats (before they released the Hydra Ice), I dunked a 160HV (essentially the same as a Hydra Ice 200HV) and the overcurrent protection shut the ESC off after spiking to just over 300A. I dried it out and it worked fine. Other people weren't so lucky though. Sometimes the overcurrent protection seemed to do nothing to prevent failure.
                  www.keithbradleyboats.com
                  • kevinpratt823
                    • Aug 2012
                    • 1361
                    #39
                    Originally posted by Rocstar
                    How are you testing bad motors? I thought about using my megger to test the windings like I use on industrial motors, but haven't tried it yet.
                    A megger will really only be good to test for a fault to ground I think. To test for compromised windings, i.e. a short against itself, you would need an extremely high resolution/accurate ohm meter.
                    My private off road rc track
                    https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
                    • IRON-PAWW
                      • Oct 2011
                      • 314
                      #40
                      I may get pounced on for this, but i would confidently run a T120a with that 1515 you are considering, even on 6s. I ran my 4074 2200kv Leopard in my Pursuit with the T120 for a whole season, only $49 risk this time. If you dont feel comfortanle about that, the Hoss T180 Steven sells here will get the job done with NO question.
                      I'm gonna agree with most that the motor is the culprit, deffinetly looks like 1/2 the windings are fried in that pic. I'm running a TFL Ariane with a Swordfish 240 Pro Plus, TP4070 1770kv, and a Prather Stainless 230 48.5mm 1.6 pitch, on 6s. After a 6 lap heat temps are 120deg.F range on everything except packs and packs are usually around 90-95deg.F Average amp draw is around 160 with spikes up to 230 or so. My set up is a bit more agressive than yours and I have no issues.
                      Ok good advice guys So... ok just looking at the ESC's Steve has got here......
                      I can go the Seaking 180 for $119.00 - yeah.. that's doable.
                      Or the Swordfish Pro 200 Amp 8S for $129.00
                      What is the pick of those two in people's opinions??
                      Will I get away with those on 6S in the Ariane Hull? And those cheaper 6S Swordfish speedy's...... can you actually run em on 6S? And in a 36in mono With that Neu 1515 1650?
                      PERTH AUSTRALIA
                      • kevinpratt823
                        • Aug 2012
                        • 1361
                        #41
                        Not familiar with your hull, but I ran a 1521/1577kv on 6s in my 33" Cyberstorm(M445) with a SK180 for quite a while and it held up just fine. I haven't owned that particular SF, so I can't speak for it, but I have had some good luck with their other controllers.
                        • IRON-PAWW
                          • Oct 2011
                          • 314
                          #42
                          Ok well the Ariane2 is a TFL Hull. 36 - 37 inches long. Nothing too off the planet Oh boy.... you can see my frikkin burnt cooling tube in this photo.....
                          Well ok... if you ran a 1521 / 1577kv on 6S with Seaking 180 then I'd wager I'd probably get away with it too in this hull with my setup. Most of my other boats actually run the seakings anyhow.
                          Add that to Make-a-Wake's advice/report above and the numbers are adding up for it.
                          I actually have 2 x Neu 1521 / 1860kv motors with the 8mm shafts that are going into a cat I have on the bench - which is partly why my spending cash is gone right now. But....... not for the Ariane I think.
                          I just wondered if the Swordfish - for the extra 20 bucks - has anything more to offer than the SK. If it's much of a muchness then I'd rather take the 20 into a seaside bar and get cocktails......
                          PERTH AUSTRALIA
                          • olwarbirds
                            Magic Smoke Wizard
                            • Oct 2012
                            • 1136
                            #43
                            uuuuuu whats that smell looks like something I'd do. I have 2 boats that the smell of magic smoke just wont go away in... DJ
                            • olwarbirds
                              Magic Smoke Wizard
                              • Oct 2012
                              • 1136
                              #44
                              Terry, the T-180 is rated to alot more amps than the SF. We have used several T-180 esc's in 6S setups running motors up too 2300kv with no probs. We have yet to burn up a T-120 or T-180, but we sure have burnt up plenty of others... DJ
                              • Make-a-Wake
                                FE Rules!
                                • 5557
                                #45
                                I havent experienced a smell like that which just doesnt leave.........even skunk odor goes away eventually.
