Swordfish Pro 200A Esc HV Programming
  • Andrewc
    • 88
    Just looking at programming the Esc´s on my 50 inch mono hull.
    This is what I have Leopard (2x) 4 Pole LBP 5692 1090 KV, (2x) Swordfish Pro 200A ESc. Will be running it on nine cell per motor. I have the programming box and it all connects and lights up nicely, however I am baffled by some of the terminology so I was wondering if anyone could help with the following which is the list it scrolls down through.
    LVC (Presume this is number of Cells) Set to 9 in my case or leave as Auto?
    LVC (Presume this is the lowest voltage I want any of the cells in a pack to reach) What voltage would you suggest is sensible?
    Brake type Options: Hard, Soft or No? I have no idea what to select.
    Timing options: Auto, 0, 2 , 4, 6…..up to 30 and then finally low? No idea
    Cut Off Type: Hard or Soft. Don´t know what it means or what to select.
    Start type (I guess this is the sensitivity of the throttle?) Choice of Standard, soft or fast. What should I select?
    PWM No idea what this is. Option of 8, 12, or 16KHz.
    Hope someone can help please. Thanks in advance.
