Can I run 6s with this setup in an outrigger? Thanks!
Swordfish 200amp and Neu 1515 1Y
The 1515 1Y is really a 4S motor for heat racing and sport running. Anything more and the runs are going to be very short and you could easily blow your esc unless you run a very small prop.Mike Chirillo
www.capitolrcmodelboats.com
I'm running a 1515 2200kv on 6S (SAW) 642 prop in a very tuned hull and I'm still pulling 260 amps spikes. Mike (Chili) is right your 200 amp esc is not going to last long. what size rigger are you setting up....DJ
PS add a capbank..this will help someTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
I'm running a CC1515 2200 with a T180 in a Jae21 on 5s turning a modified 1450 prop. it runs cool, never gets over 115 degrees. Gps showed my fastest pass last year was 84 mph. And that was with some old Zippys I have. Got some new Giant Power lipos this year but haven't had time to really try and push them yet.
100_0015.jpg100_0021.jpg100_0020.jpg100_0023.jpg100_0024.jpgModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
[ATTACH=CONFIG]119253[/ATTACH][ATTACH=CONFIG]119254[/ATTACH][ATTACH=CONFIG]119255[/ATTACH][ATTACH=CONFIG]119256[/ATTACH][ATTACH=CONFIG]119257[/ATTACH]32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Its in a cat hull..Genesis...I just wanted to give ya an example of amp draws...those T-180 esc's can handle higher amp spikes than my castle 240..we use them in most of our 4-8S set-ups...I would still add capbank....try 4S then 6S, just keep an eye on temps till ya get it tuned....
I got to get one of these JAE riggers....maybe I can get some setup tips from SirBudman....Travis you need a rigger too bro....DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
I got to get one of these JAE riggers....maybe I can get some setup tips from SirBudman....Travis you need a rigger too bro....DJ32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I dont own a rigger "YET" so I for sure have alot to learn. So far I'm seeing that possibly riggers run more effienctly...look forward to hearing how op makes out with his setup because I have several of those 1515 2200kv motors looking for a home....DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
