Swordfish Pro+ 220A
  • ezhitz
    • Aug 2009
    • 428
    Swordfish Pro+ 220A
    Hi
    I had a chance to finally try out my new swordfish esc which seamed to work ok without any heat issues some people seam to be having.
    I what I noticed when reviewing to data log was I only seemed to get 92.8% max throttle. The radio is a Futaba 2Pl I adjusted the throttle
    epa to 120%. Is there something else I should do.
    Thanks Jack
    :canada
  • cacofonix
    • Jul 2008
    • 240
    hello
    have you update firmware ?
    • drwayne
      • May 2008
      • 2981
      set the Tx to 100% ..calibrate the Tx throttle to esc.. then up the Tx to 120% . problem solved
      • IRON-PAWW
        • Oct 2011
        • 314
        So..... when you say set tx to 100%, 120% etc ..... how exactly do you do that? Using throttle trim? About to set up my own 240a Swordfish and was wondering about this.
        PERTH AUSTRALIA
        • ezhitz
          • Aug 2009
          • 428
          Thanks for the answers. I will try what drwayne said and try it again next weekend.
          :canada
          • drwayne
            • May 2008
            • 2981
            digital trim width per channel.. from +120% → -120%.
            set those at 100% both ends.
            Now the fun part.
            calibrate that to the esc via Rx
            ezhitz... you will do fine :2thumbsup:
